I am trying to obtain an IP address from a host. The available Ping nodes does not seem to return the IP address, so I tried the EXEC node with the following command:
nslookup myhost.com
This worked, but the object returned is not well formatted, so I could not extract the IP address easily.
The complete msg object looks like this:
{"_msgid":"ef79c141.ca169","payload":"Address:\t11.22.33.44:53\n\nNon-authoritative answer:\nNon-authoritative answer:\nName:\tmyhost.com\nAddress: 11.22.33.44\n\n"}
I appreciate if anyone could point me in the right direction. I just need the ip address from this whole message.
You could (in a function node) use a regular expression or the string split method.
Thanks @Steve-Mcl, but I am trying to keep it simple.
I tried the following EXEC command and it seems to work so far:
getent hosts myhost.com | awk '{ print $1 }'
The message payload contains the IP address only, which is what I wanted.
That wasn't your question though, you asked...
Hey ho, all well that ends well.
If you are making less than 1,000 calls per month, you could use a free https://geo.ipify.org/docs account.
I've used them for years, and very reliable.
A GET call; https://geo.ipify.org/api/v1?apiKey=at_EHuas86RK4ujhduhsdssffb0JF9&domain=bbc.co.uk
returns a payload.ip of "151.101.0.81" plus lots of other information if you need/want it.
