How can i use the value of a variable i created inside the template node
they can be chosen dynamically it's not a one static file it changes and you can also choose multiple files and you can choose different files each time that's the problem and the size of the files are big so that's what's causing the problem. I can pass them through node i figured how from the documentation you provided to me but its causing a problem because of the file size
