I am getting a 12 character string value with a terminating character over TCP/IP. But I get a data type error in the debug message. "TypeError: The argument 'newPath' must be a string or Uint8Array without null bytes. Received 'D:registration42026659000Bx00.ravi'. What could be the reason? Regards
somewhere in your flow you append d:\ and ???.ravi to that string right?
It certainly looks like the ??? is null
Show us more info like your flow or any function code that generates that file name
"id": "9503357ecd6ba5f6",
"type": "tcp in",
"z": "ea87b1398b776bca",
"name": "L2 COIL ID",
"server": "server",
"host": "",
"port": "2001",
"datamode": "stream",
"datatype": "utf8",
"newline": "",
"topic": "",
"trim": false,
"base64": false,
"tls": "",
"x": 140,
"y": 380,
"2ba89f82.e7991",
"a7b2c1d1fe0681e5",
"7a876ca634443420"
"id": "7a876ca634443420",
"type": "delay",
"name": "Record out time for file saving.",
"pauseType": "delay",
"timeout": "90",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 530,
"y": 440,
"33e06930.8b5856"
"id": "33e06930.8b5856",
"type": "fs-ops-dir",
"path": "D:\\cam",
"pathType": "str",
"filter": "*.ravi",
"filterType": "str",
"dir": "files[0]",
"dirType": "msg",
"x": 740,
"y": 440,
"567fa9ed.c8bd88"
"id": "567fa9ed.c8bd88",
"type": "function",
"func": "msg.test123 = msg.payload+\".ravi\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 890,
"y": 440,
"363603f0.472b6c"
"id": "363603f0.472b6c",
"type": "fs-ops-move",
"sourcePath": "D:\\cam",
"sourcePathType": "str",
"sourceFilename": "files[0]",
"sourceFilenameType": "msg",
"destPath": "D:\\kayit",
"destPathType": "str",
"destFilename": "test123",
"destFilenameType": "msg",
"link": false,
"x": 1060,
"y": 440,
"7be896a9b5f97561"
"id": "7be896a9b5f97561",
"type": "debug",
"name": "debug 3",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1280,
"y": 440,
I think that you need to trim the input msg.payload string, it appears to have a spurious null on the end.
You can do that using a function node and javascript or using a change node using JSONata.
