How check context exist
hi
I receive data but before updated I need check if data it's same or this object if exist or not
so if exist check is data if equal else update
or if not exist save it
example check object "V06-bus" exist or not
how that
context
With function node most simple case may be something like this
var stored = flow.get("stored")
// if stored object has not created yet, it is undefined
node.warn("check "+stored)
if(stored != msg.payload){
    // incoming data is not same as stored data
    node.warn("stroing "+msg.payload)
    flow.set("stored", msg.payload)
