How do I declare an array element in OpcUa-Item node
Hi All,
I am new to node-red and I am developing a simulation environment for a PLC using OPC-UA. I added some values to the OPCUA server in the PLC, and tested them in UAExpert Client:
One of them is a boolean, to enable the simulation
Other are boolean arrays of elements, for the simulated inputs and outputs
The problem comes in the web environment, when I try to simulate a fault in the system by toggling an element on the array (I have tried the Boolean and it works fine).
In OpcUa-Item node, I added:
For the Simulation boolean:
Item: "ns=4;s=Root.SimulationON"
Type: "Boolean"
For the Fault bit into the Array
Item: "ns=4;s=Root.DIArraySim[17]"
Type: "Boolean"
After Deploying , I flicked the a switch and only the simulation boolean works, but the element in the array cannot be found. It shows error The node id refers to a node that does not exist in the server address space
I could not find any reference to this in any forum. I have been trying different things but nothing worked. Perhaps I am missing something simple.
I attach the nodes so you can have a look.
        "id": "54b85cea1233730f",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "921f7afec8789911",
        "type": "OpcUa-Item",
        "z": "54b85cea1233730f",
        "item": "ns=4;s=Root.SimulationON",
        "datatype": "Boolean",
        "value": "",
        "name": "SimON",
        "x": 560,
        "y": 200,
                "e3c148c343a44193"
        "id": "d6bf2d5d03473384",
        "item": "ns=4;s=Root.DIArraySim[17]",
        "value": "",
        "name": "109U01_Fault",
        "x": 580,
        "y": 260,
                "e3c148c343a44193"
        "id": "e3c148c343a44193",
        "type": "OpcUa-Client",
        "endpoint": "e49ccceb2c1debc5",
        "action": "write",
        "deadbandtype": "a",
        "deadbandvalue": 1,
        "time": "1",
        "timeUnit": "s",
        "certificate": "n",
        "localfile": "",
        "localkeyfile": "",
        "securitymode": "None",
        "securitypolicy": "None",
        "useTransport": false,
        "maxChunkCount": "",
        "maxMessageSize": "",
        "receiveBufferSize": "",
        "sendBufferSize": "",
        "setstatusandtime": false,
        "keepsessionalive": false,
        "name": "OPCUA_WRITE",
        "x": 800,
        "y": 200,
        "id": "5dc7af7298669d90",
        "type": "ui_switch",
        "label": "SimulationON",
        "tooltip": "",
        "group": "212183c70d99713f",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": false,
        "decouple": "false",
        "topic": "topic",
        "topicType": "msg",
        "style": "",
        "onvalue": "true",
        "onvalueType": "bool",
        "onicon": "",
        "oncolor": "",
        "offvalue": "false",
        "offvalueType": "bool",
        "officon": "",
        "offcolor": "",
        "animate": false,
        "className": "",
        "x": 360,
        "y": 200,
                "921f7afec8789911"
        "id": "92bf8898f2056fbc",
        "label": "109U01_Fault",
        "tooltip": "",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": true,
        "topic": "topic",
        "topicType": "msg",
        "style": "",
        "onvalue": "true",
        "onicon": "",
        "oncolor": "",
        "officon": "",
        "offcolor": "",
        "animate": false,
        "className": "",
        "x": 360,
        "y": 260,
                "d6bf2d5d03473384"
        "id": "e49ccceb2c1debc5",
        "type": "OpcUa-Endpoint",
        "endpoint": "opc.tcp://192.168.147.4:48020",
        "secpol": "None",
        "secmode": "None",
        "none": true,
        "login": false,
        "usercert": false,
        "usercertificate": "",
        "userprivatekey": ""
        "id": "212183c70d99713f",
        "type": "ui_group",
        "name": "DevBox01",
        "tab": "2d0adb55be7122fc",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": false,
        "className": ""
        "id": "2d0adb55be7122fc",
        "type": "ui_tab",
        "name": "Profelis",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Kind regards
