How do I filter a status?
hello,
i'm use Node Red for Home Assistant.
i need to filtrate a status becaus i can't use ZONE for geolocalize user.
I use Geocoede location by iphone but i have status with adress e not "home" or "not_home"
How do i filtrer this status?
thk
sorry for my english
Welcome to the forum @nicolab74
Do you mean you are getting status messages from a Status node and need to extract data from that message? If so then show us some sample messages and what you need to get out.
You would normally use a switch node to filter/route the incoming payload status from your incoming node.
i.e
property payload
rule1
== (equals) A/Z (string) home
rule2
== (equals) A/Z (string) not_home
yes
i have the status message:
Via Salisburgo 10 37136 Verona Veneto Italy at: Aug29, 13:29
i need to filtrate
when the state is : Via Salisburgo ( not all text only )
i have test with if State : IS if State: In but without success
then i have a change for set
set state : home
You can use a Switch node configured to test if msg.payload Includes that text
yesss...!!!!!!!!!!!!!!!!!!
sorry
simpler than expected
