How do I get to the content of this payload?
I've got an iCal node that is returning the content in the screenshot below, it returns an object in an array[1] when there is an upcoming event that matches the filtering criteria I've given the node and I want to then use a switch to deal with this input. It returns an [ empty ] in an array[0] when there is no match, I can't see this either.
Here is what I've tried:
msg.payload
msg.payload.value
msg.payload.summary (summary is the field I want to look at)
but I can't 'see' the data in the subsequent switch node
Just found this:
: copies the path to the selected element to your clipboard. In this example, it will copy payload.Phone[2].type . This allows you to quickly determine how to access a property in a Change or Function node. : copies the path to the selected element to your clipboard. In this example, it will copy payload.Phone[2].type . This allows you to quickly determine how to access a property in a Change or Function node.
