How do I separate and define two of my variables?
I have code that is outputting an x value, a y value, a max value, a radius value, and a theta value within my Raspberry Pi that updates every second.
An example output looks like this below:
Highest Number: 31.9029
x: -15
y: 8
Radius: 17.0
Theta: -28.07
What I'm trying to do through Node Red on my Raspberry Pi is output only the Radius value and the Theta value separately.
I simply did this to test for simply my radius value:
timestamp --
exec (My Python Script, while the command is running, spawn mode is enabled) --
switch node (contains "Radius") --
debug
But my output is showing different things almost every single time.
One output
Radius:
Another output
y: 8
x: -15
Another output
y: 8
Radius: 17.9
Theta: 30.96
It's all pretty ugly. Is there a way to get these outputs in a better way on Node Red?
You have the script, so you can modify what output it produces. Python can generate json as well, perhaps a bit easier to deal with in node-red. (parsing the output is also possible ofcourse)
That does make sense. Thank you. It works great. I was scared because I'm using a thermal camera to gather this information and I didn't know if processing multiple code would be too much for Node Red or the Pi
