How to add ( or append ) new variables to a payload
hello, i am new here and I am trying to add a variable devEui that will be eaul to a value received in payload
//  new variable  --
var devEui =msg.end_device_id;
var http_packet = {
    payload: {
        data: msg.rx_data,
        network: "kerlinkSPN",
        source: "xxxxF53416",
        //inject new variable to data sent with payload -- >>     **devEui: ??? ,**
    headers: {
        "content-type": "application/json"
return http_packet;
ADMIN Edit: Wrapped code in a code block (three backticks) for readability
Just set
payload.devEui = 'your content';
Thanks !
If.the Content is another variable coming from the telemetry what is the sintaxis ?
The variable that comes is
"Device_end_id" and the value ( deveui) has to be assigned to devEui
Which is the value recognized by the mqtt broker
If Device_end_id is already a javascript variable then all you need is
http_packet.payload.devEui = Device_end_id
However, I suspect that Device_end_id may not be a simple javascript variable of that name. If so then give us more information about what that variable is.
Add it like the data variable
var http_packet = {
    payload: {
        data: msg.rx_data,
        devEui: devEui    // <<---- add devEui to payload
    headers: {
return http_packet;
alternatively...
var http_packet = {
    payload: {
        data: msg.rx_data,
    headers: {
http_packet.payload.devEui = devEui    // <<---- add devEui to payload
return http_packet;
it should work ! :frowning:
the other TWO VARIABLES network and source come in at the end, but not devEui
replaced deEui with ": test" and it works
so the problem is in getting the telemetry value from end_device_id
You are using msg.end_device_id have you checked the msg BEFORE it goes in to the function?
Canned text...
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
Just remember to prefix the copied path with msg.
hint
it's probably msg.payload.data.end_device_id
thank you ALL.. still working on the receiving end, since the dveui data finally was created, but it goes as header information , not part of the "telemetry" .. next to solve
solution
var devEui = msg.rx_data.end_device_id;
