I'm trying to build a function where I could input some temperature value limits, that are then used else were in the project. Like I could give a number that is how low and how high temperature can get. This is for a kind of setup page in my system.
In this example I have two v-text-field elements just for testing.
<template>
<v-text-field
v-model="range[0]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
@update:model-value="send({payload: range})"
></v-text-field>
<v-text-field
v-model="range[1]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
></v-text-field>
</template>
<script>
export default {
data() {
return {
range:[5,6],
</script>
I would like to send a payload with an array to the template and have my numbers update the ones that are currently in the "Range"-array. So when someone has changed those limits, the template is using the correct stored numbers.
When the user changes a value, it's then sent out using the @update function and that works. When I change the numbers, I get them out as a stings. I then have a separate function to push them trough a parseFloat. Ideally I would like them to be sent as numbers so I don't need to fix them.
How can I read in msg.payload?
How can I update the range-array with the one in the payload?
I know that the whole template should be built differently and have tried scopes and Watches and so fort, but have not found a working solution.
You could add a watch on "msg". When something about the msg matches your requirements, update the local data value.
export default {
data() {
return {
range:[5,6],
watch: {
msg: function () {
if (msg.topic === "set") { // optional topic check
this.range = this.msg.payload
Thanks Steve.
As a last ditch effort, I decided to try ChatGPT. And what do you know, it seem to know a lot about the issue. After couple of iterations, I was at a point where it would give me a code that can read in an array:
<template>
<v-text-field
v-model="value[0]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
></v-text-field>
<v-text-field
v-model="value[1]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
></v-text-field>
</template>
<script>
export default {
data() {
return {
value: [5, 6],
watch: {
msg: {
handler(newVal) {
// Update the value array when the msg changes
this.value = newVal.payload;
deep: true,
</script>
Or a code that can output an array:
<template>
<v-text-field
v-model="value[0]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
@input="updateValue(0)"
></v-text-field>
<v-text-field
v-model="value[1]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
@input="updateValue(1)"
></v-text-field>
</template>
<script>
export default {
data() {
return {
value: [5, 6],
methods: {
updateValue(index) {
// Update the specific value in the array
this.value[index] = parseFloat(this.value[index]);
// Send the updated values to Node-RED
this.send({ payload: this.value });
</script>
But it never gave one that does both. So is just combined them and now it works
This is the one that can read and write an array.
<template>
<v-text-field
v-model="value[0]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
></v-text-field>
<v-text-field
v-model="value[1]"
density="compact"
style="width: 70px"
type="number"
variant="outlined"
hide-details
single-line
></v-text-field>
</template>
<script>
export default {
data() {
return {
value: [5, 6],
methods: {
watch: {
msg: {
handler(newVal) {
deep: true,
</script>
