You can try this flow:
"id": "061b7f51de6e3f24",
"type": "inject",
"z": "a442b54b44edc349",
"props": [
"p": "payload.payments",
"v": "[{\"type\":\"card\",\"amount\":1231.15},{\"type\":\"cash\",\"amount\":99.15},{\"type\":\"card\",\"amount\":1231.15},{\"type\":\"cash\",\"amount\":99.15}]",
"vt": "json"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 190,
"y": 140,
"58684a2daf702d68"
"id": "3617d84d9f3673eb",
"type": "split",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"arraySpltType": "len",
"stream": false,
"addname": "",
"x": 550,
"y": 140,
"6f49662d80bcc2c5"
"id": "3d43b37bc60ef510",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1250,
"y": 140,
"id": "6830e799f0c7d768",
"type": "join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": true,
"timeout": "",
"count": "1",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 870,
"y": 140,
"898ba01ab384793d"
"id": "58684a2daf702d68",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.payments",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 370,
"y": 140,
"3617d84d9f3673eb"
"id": "6f49662d80bcc2c5",
"type": "function",
"func": "var sum = context.get(msg.payload.type) || 0;\nsum = sum + msg.payload.amount;\ncontext.set(msg.payload.type,sum);\nmsg.topic = msg.payload.type;\nmsg.payload = sum;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 700,
"y": 140,
"6830e799f0c7d768"
"id": "c5d25f23090950e9",
"type": "inject",
"name": "reset",
"props": [
"p": "reset",
"v": "true",
"vt": "bool"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 690,
"y": 200,
"6830e799f0c7d768"
"id": "898ba01ab384793d",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "payl",
"duration": "250",
"extend": true,
"overrideDelay": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 1040,
"y": 140,
"3d43b37bc60ef510"
For sure you can calculate everything within the function node, but this gives in my opinion more an idea how to use the different nodes.
