No just delete error property count, msg.error.source.count each loop
[{"id":"958f10a1.7f7","type":"inject","z":"8d8a515a.78af18","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"count","v":"0","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"ftp values etc","payloadType":"str","x":160,"y":1380,"wires":[["46bbcb02.5fae34"]]},{"id":"46bbcb02.5fae34","type":"switch","z":"8d8a515a.78af18","name":"count greater than 6","property":"count","propertyType":"msg","rules":[{"t":"lt","v":"20","vt":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":390,"y":1380,"wires":[["7197c896.b788c8"],["6d3c581.f0c04a8"]]},{"id":"6d3c581.f0c04a8","type":"change","z":"8d8a515a.78af18","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Failed to send file!","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":1420,"wires":[["13e0fbb5.197cc4"]]},{"id":"d0c9a4de.c79f38","type":"delay","z":"8d8a515a.78af18","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":390,"y":1440,"wires":[["46bbcb02.5fae34"]]},{"id":"7197c896.b788c8","type":"http request","z":"8d8a515a.78af18","name":"ftp simulate","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://www.hfhfhhhdjk.com","tls":"","persist":false,"proxy":"","authType":"","x":760,"y":1360,"wires":[[]]},{"id":"13e0fbb5.197cc4","type":"debug","z":"8d8a515a.78af18","name":"Failed to send file!","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":870,"y":1420,"wires":[]},{"id":"faeb86e6.459f98","type":"change","z":"8d8a515a.78af18","name":"clear error","rules":[{"t":"set","p":"error.source.count","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"count","pt":"msg","to":"count+ 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1500,"wires":[["d0c9a4de.c79f38"]]},{"id":"b327d5f9.4a55f8","type":"catch","z":"8d8a515a.78af18","name":"catch [ftp] node","scope":["7197c896.b788c8"],"uncaught":false,"x":170,"y":1500,"wires":[["faeb86e6.459f98","ea5b1d29.6d31f"]]},{"id":"ea5b1d29.6d31f","type":"debug","z":"8d8a515a.78af18","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":240,"y":1620,"wires":[]}]
