How to change button background color temporarily onclick
On my dashboard I have a button which confirms a selected time of a time input widget
How can I change the background color, after the confirmation (onclick), for a given period and then go back to the initial background color?
you could attach a trgger node.
eg.
[{"id":"3b6120fe.503528","type":"inject","z":"84b6531c.4e773","name":"","props":[{"p":"background","v":"green","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","x":450,"y":120,"wires":[["ba040ee4.a8d0c"]]},{"id":"ba040ee4.a8d0c","type":"ui_button","z":"84b6531c.4e773","name":"","group":"2d4fe667.28f8ba","order":16,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"{{background}}","className":"","icon":"","payload":"1","payloadType":"str","topic":"topic","topicType":"msg","x":610,"y":120,"wires":[["9142fd98.891598","ebb5c8e.2b53538"]]},{"id":"15f8a7f.c025758","type":"change","z":"84b6531c.4e773","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"background","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":180,"wires":[["ba040ee4.a8d0c"]]},{"id":"9142fd98.891598","type":"trigger","z":"84b6531c.4e773","name":"","op1":"red","op2":"green","op1type":"str","op2type":"str","duration":"1","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":470,"y":180,"wires":[["15f8a7f.c025758"]]},{"id":"ebb5c8e.2b53538","type":"debug","z":"84b6531c.4e773","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":80,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":1,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thanx man! working
Is this also possible in css code in my template node?
This will save me 14 extra widgets in my flow
Yes it is possible, if you give each button a optional class, you could then target that class in your css some examples here
Thanx, found it!
