How to change the colour of this icon. FA-Icon
I am using the fa icon group and have this bit of code.
if (msg.payload == "On-line")
    msg  = {payload: '<i class="fa fa-bullseye fa-2x nr-dashboard-ok"></i>'};
    node.status({fill:"green",shape:"dot",text:"On-line"});
} else
    msg  = {payload: '<i class="fa fa-bullseye fa-2x nr-dashboard-error"></i>'};
    node.status({fill:"red",shape:"dot",text:"Off-line"});
Where I am falling over is the colour.
Status quo, the colour is set by the nr-dashboard-ok part.
And there are two options. ok or error.
Ok, I can change the definition of the colour. But alas it isn't that simple.
I am wanting to have three colours.
But to maintain the standard, I have to use the nr-dashboard-xxx part.
Where can I get a list of how to put more options in there.
I have looked at this site:
nr-dashboard
But I get confused when it goes to the:
and the line below.
body.nr-dashboard-theme .nr-dashboard-color { color: @groupTextColor; }
Because if I make the line:
    msg  = {payload: '<i class="fa fa-bullseye fa-2x nr-dashboard-color { color: #888829; }"></i>'};
It doesn't work.
I picked the values at random. But I am wanting a kind of yellow colour.
Thanks in advance.
For yellow use the "warning" class
Appreciated.
I am confused though with the other stuff around it.
I haven't got enough courage (?) to know all the workings of how "nr-dashboard-warning" works.
I am sure I tried it and all I got was a WHITE version of the icon, not a yellow one, so where does that code set the colour?
Just asking.
This is the line I (finally) got to work:
msg  = {payload: '<i class="fa fa-bullseye fa-2x nr-dashboard-warning { color: #eaf42f; }"></i>'};
You could use the font-color tag instead, for other colors:
Explaining: nr-dashboard-warning is the name of a CSS class. Inside the class definition you can see what is the color defined.
body.nr-dashboard-theme .nr-dashboard-error { color: #ff2929; }
body.nr-dashboard-theme .nr-dashboard-warning { color: #eaf42f; }
body.nr-dashboard-theme .nr-dashboard-ok { color: #49db3c; }
Again: Thanks.
But (sorry) I don't have the fields you show.
I don't know how to "identify the node" once it is in a flow.
I think it is a NUMBER input node... Dunno, but this is the code:
Oh, there you go. It is a UI_TEXT node - I think. Top line in the code.
[{"id":"215b8976.4a058e","type":"ui_text","z":"c636aa5a.cc34","group":"1f5fe937.c354c7","order":1,"width":"2","height":"1","name":"82","label":"82","format":"{{msg.payload}}","layout":"row-center","x":3510,"y":550,"wires":[]},{"id":"1f5fe937.c354c7","type":"ui_group","z":"","name":"Cat-5","tab":"1c792414.600e94","order":3,"disp":true,"width":"10","collapse":false},{"id":"1c792414.600e94","type":"ui_tab","z":"","name":"Telemetry","icon":"dashboard","order":2}]
But where are these lines?
In which file?
(Sorry if we are tripping over each other's replies.)
The screenshot I have used was taken from the config of an inject node. It is the easier way for you to test.
Flow:
[{"id":"b195cce4.3c5d5","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"f4996196.d495","type":"ui_text","z":"b195cce4.3c5d5","group":"3dfd1195.df4f4e","order":4,"width":"1","height":"1","name":"indicator","label":"","format":"{{msg.payload}}","layout":"row-center","x":560,"y":160,"wires":[]},{"id":"a2b85955.22e8a8","type":"inject","z":"b195cce4.3c5d5","name":"unlock","topic":"","payload":"<font color= #00A4DE><i class=\"fa fa-lightbulb-o fa-2x\"></i></font>","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":390,"y":160,"wires":[["f4996196.d495"]]},{"id":"3dfd1195.df4f4e","type":"ui_group","z":"","name":"Test","tab":"d50effcd.c6b68","disp":true,"width":"6","collapse":false},{"id":"d50effcd.c6b68","type":"ui_tab","z":"","name":"Test","icon":"dashboard","order":5}]
My reply: From the very same link you have shared in your post.
nr-dashboard
Ok....
(catch up time)
This line was added (replaced) and all seems to work, and I think it is "tidier" than the mess I had.
        msg  = {payload: '<font color = "yellow" i class="fa fa-bullseye fa-2x"></i>'};
That link I mentioned confused me, as it went on and did/does say that, but (to me) it is out of context, as it doesn't say (clearly enough) where they are assingned.
It only shows code.....
But not where/how to set them.
Maybe I need to learn a bit more about it.
But it is working and I have learned a bit more.
Thing is, I think something else has been pushed out the other end/side. Shame I don't know what that is though. :frowning:
Good, if it was useful for your it may be for someone else in the future so please mark the post as resolved. :wink:
