Hello!
I am using the node-red-contrib-google-iot-core (version 0.0.4) to connect via MQTT with my Google IoT Broker.
I want to change a little bit the code of this Node. Is that possible?
I want to change the code that it's in the address /home/pi/.node-red/node_modules/node-red-contrib-google-iot-core/google-iot-core.js
In function createJwt I want to change:
'exp': Math.round(Date.now() / 1000) + 60 * 60, // 60 minutes
'exp': Math.round(Date.now() / 1000) + 60 * 60 * 24, // 24 hours
What steps should I follow to make it work the changes that I have done in google-iot-core.js?
Thank you!
