How to check duplicate data and not insert to sql
var value = 6
var pld
pld = "INSERT INTO [HIG].[dbo].[Alum]"
pld = pld + "([Aluminium])"
pld = pld + "VALUES ('" + value + "')"
msg.payload = pld
IF value equals 6 not insert data to sql
> ?? How to check ??
I don't understand, you are setting 'value' to six.
Are you trying to see if the msg entering your function has a value of 6? If so, add a switch node before the function node to test for 6 and don't pass the msg if it does.
Or do you want to only INSERT if a record already exists WHERE value = 6 ?
If so, what dbms are you using?
sql server management studio
if data is duplicate not insert
