Sorry @zenofmud , for not sharing the flow, I've actually tried to modify the flow but I could help.
[{"id":"663256c1.ef9618","type":"ui_text_input","z":"a0a2199f.f5e638","name":"name","label":"Name","tooltip":"","group":"356fac5d.d980c4","order":2,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"name","x":570,"y":280,"wires":[["9c430827.1649e8"]]},{"id":"8e6c4c9d.3b383","type":"ui_text_input","z":"a0a2199f.f5e638","name":"apellido","label":"apellido","tooltip":"","group":"356fac5d.d980c4","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"apellido","x":580,"y":340,"wires":[["9c430827.1649e8"]]},{"id":"12a585f6.e531ba","type":"ui_button","z":"a0a2199f.f5e638","name":"save-button","group":"356fac5d.d980c4","order":7,"width":0,"height":0,"passthru":true,"label":"Guardar datos","tooltip":"","color":"","bgcolor":"","icon":"assignment_turned_in","payload":"{}","payloadType":"global","topic":"save-button","x":570,"y":560,"wires":[["9c430827.1649e8","228f7175.69169e"]]},{"id":"9dbf8c03.4e568","type":"debug","z":"a0a2199f.f5e638","name":"node_switch1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1140,"y":340,"wires":[]},{"id":"9c430827.1649e8","type":"join","z":"a0a2199f.f5e638","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"5","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":340,"wires":[["e4b9d7ca.a5ec88","60ccb3fe.4bcd8c"]]},{"id":"e4b9d7ca.a5ec88","type":"switch","z":"a0a2199f.f5e638","name":"switch_select","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"save-button","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":910,"y":360,"wires":[["9dbf8c03.4e568","d084b396.0651d"]]},{"id":"7aa36605.3867e8","type":"debug","z":"a0a2199f.f5e638","name":"node_bd_pac","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1380,"y":320,"wires":[]},{"id":"60ccb3fe.4bcd8c","type":"debug","z":"a0a2199f.f5e638","name":"node_join","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1020,"y":280,"wires":[]},{"id":"d084b396.0651d","type":"function","z":"a0a2199f.f5e638","name":"select-query","func":"var select = {topic: \"SELECT COUNT(*) AS count FROM pacientes WHERE nombre='\" + msg.payload.name + \"'\"};\nreturn select;","outputs":1,"noerr":0,"x":950,"y":420,"wires":[["8a6f7674.c3ec98","8dd0ca48.b80278","bfb6b546.6fabd8"]]},{"id":"8a6f7674.c3ec98","type":"debug","z":"a0a2199f.f5e638","name":"node_select","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1030,"y":500,"wires":[]},{"id":"1fa2ae8b.72e9c1","type":"ui_text_input","z":"a0a2199f.f5e638","name":"edad","label":"edad","tooltip":"","group":"356fac5d.d980c4","order":5,"width":0,"height":0,"passthru":false,"mode":"number","delay":"300","topic":"edad","x":570,"y":440,"wires":[["9c430827.1649e8"]]},{"id":"951ae802.19d948","type":"ui_text_input","z":"a0a2199f.f5e638","name":"sexo","label":"sexo","tooltip":"","group":"356fac5d.d980c4","order":6,"width":0,"height":0,"passthru":false,"mode":"text","delay":"300","topic":"sexo","x":570,"y":500,"wires":[["9c430827.1649e8"]]},{"id":"ade31e4f.08585","type":"ui_text_input","z":"a0a2199f.f5e638","name":"cedula","label":"cedula","tooltip":"","group":"356fac5d.d980c4","order":4,"width":0,"height":0,"passthru":true,"mode":"number","delay":300,"topic":"cedula","x":570,"y":400,"wires":[["9c430827.1649e8","e0ca343.98933c8"]]},{"id":"13b7e857.884ca8","type":"change","z":"a0a2199f.f5e638","name":"set","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":400,"wires":[["8b7d066a.c7e1a8"]]},{"id":"8b7d066a.c7e1a8","type":"ui_button","z":"a0a2199f.f5e638","name":"clear-button","group":"356fac5d.d980c4","order":8,"width":0,"height":0,"passthru":false,"label":"Borrar campos","tooltip":"","color":"","bgcolor":"","icon":"delete","payload":"[]","payloadType":"json","topic":"","x":370,"y":400,"wires":[["663256c1.ef9618","8e6c4c9d.3b383","ade31e4f.08585","951ae802.19d948","1fa2ae8b.72e9c1","12a585f6.e531ba"]]},{"id":"228f7175.69169e","type":"debug","z":"a0a2199f.f5e638","name":"node-button","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":790,"y":560,"wires":[]},{"id":"8dd0ca48.b80278","type":"mysql","z":"a0a2199f.f5e638","mydb":"698ecd0.1670e34","name":"BD_DATOS","x":1150,"y":400,"wires":[["7aa36605.3867e8"]]},{"id":"e0ca343.98933c8","type":"debug","z":"a0a2199f.f5e638","name":"cedula","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":800,"y":500,"wires":[]},{"id":"2480d039.f669e","type":"function","z":"a0a2199f.f5e638","name":"insert-query","func":"insert = {topic: \"INSERT INTO pacientes (nombre,apellido,cedula,edad,sexo) VALUES ('\" + msg.payload.name + \"','\" + msg.payload.apellido + \"','\" + msg.payload.cedula + \"','\" + msg.payload.edad + \"','\" + msg.payload.sexo + \"')\"};\nactionString = \"Dato ingresado satisfactoriamente!\";\nreturn [insert,actionString];\n\n\n//insert = {topic: \"INSERT INTO pacientes (nombre,apellido,cedula,edad,sexo) VALUES ('\" + msg.payload.name + \"','\" + msg.payload.apellido + \"','\" + msg.payload.cedula + \"','\" + msg.payload.edad + \"','\" + msg.payload.sexo + \"')\"};\n//return insert; \n","outputs":1,"noerr":0,"x":1410,"y":480,"wires":[["d63e1165.fd7fe","628ee543.03c4ac"]]},{"id":"bfb6b546.6fabd8","type":"switch","z":"a0a2199f.f5e638","name":"switch_insert","property":"payload[0].count","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"msg"},{"t":"eq","v":"1","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":1190,"y":460,"wires":[["975efbe.6731308","2480d039.f669e"],["db614880.d35f48","7150fef5.16df6"]]},{"id":"db614880.d35f48","type":"function","z":"a0a2199f.f5e638","name":"failure-msg","func":"actionString = \"Ya se ingresado ese nombre!\";\nmsg.payload = actionString;\nreturn msg;","outputs":1,"noerr":0,"x":1410,"y":540,"wires":[["add1cfb6.0b88e"]]},{"id":"d63e1165.fd7fe","type":"mysql","z":"a0a2199f.f5e638","mydb":"698ecd0.1670e34","name":"BD_DATOS","x":1590,"y":480,"wires":[["a6c52cd3.8dfe1"]]},{"id":"1583bc32.a442d4","type":"function","z":"a0a2199f.f5e638","name":"select-query","func":"insert = {topic: \"INSERT INTO pacientes (nombre,apellido,cedula,edad,sexo) VALUES ('\" + msg.payload.name + \"','\" + msg.payload.apellido + \"','\" + msg.payload.cedula + \"','\" + msg.payload.edad + \"','\" + msg.payload.sexo + \"')\"};\nreturn insert; ","outputs":1,"noerr":0,"x":1030,"y":620,"wires":[[]]},{"id":"628ee543.03c4ac","type":"debug","z":"a0a2199f.f5e638","name":"node_insert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1600,"y":420,"wires":[]},{"id":"add1cfb6.0b88e","type":"debug","z":"a0a2199f.f5e638","name":"node_fallo","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1650,"y":580,"wires":[]},{"id":"a6c52cd3.8dfe1","type":"debug","z":"a0a2199f.f5e638","name":"node_bdpacientes","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1800,"y":520,"wires":[]},{"id":"7150fef5.16df6","type":"debug","z":"a0a2199f.f5e638","name":"node_siwtch3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1410,"y":620,"wires":[]},{"id":"975efbe.6731308","type":"debug","z":"a0a2199f.f5e638","name":"node_siwtch2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1380,"y":400,"wires":[]},{"id":"a942a4fe.805278","type":"ui_toast","z":"a0a2199f.f5e638","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Ingreso correcto del paciente","name":"Ingreso correcto del paciente","x":1640,"y":340,"wires":[[]]},{"id":"87508a4f.47d1e8","type":"ui_toast","z":"a0a2199f.f5e638","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"fallo","name":"fallo","x":1630,"y":640,"wires":[[]]},{"id":"356fac5d.d980c4","type":"ui_group","z":"","name":"Pacientes","tab":"16e86f12.023081","order":2,"disp":true,"width":"6","collapse":true},{"id":"698ecd0.1670e34","type":"MySQLdatabase","z":"","host":"","port":"","db":"","tz":""},{"id":"16e86f12.023081","type":"ui_tab","z":"","name":"dispositivo","icon":"healing","order":2}]
