How to combine text input node with button node
How can I have a text input where the user enters a value (possibly with a preceding Inject to set the default value), and a button node, that when clicked, takes the value of the text input and sends it out.
Just chaining a text input to a button node doesn't work as the button node will overwrite the msg.payload. I guess I am looking for a button that interrupts the flow until the button is pressed. So it doesn't change the msg object, it just waits with outputting whatever came in until the button is clicked.
Hello !
If the question is always open, you can do as above :
and the associated flow:
[{"id":"4ec0caef.1d59ac","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"a444821b.ba15c8","type":"ui_text_input","z":"4ec0caef.1d59ac","name":"1","label":"1 : ","tooltip":"","group":"9b65de7c.212788","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"0","topic":"1","x":321,"y":161,"wires":[["61a8669.9179598"]]},{"id":"a73fc64c.d6551","type":"ui_button","z":"4ec0caef.1d59ac","name":"","group":"9b65de7c.212788","order":1,"width":"3","height":"1","passthru":false,"label":"Save","tooltip":"","color":"","bgcolor":"","icon":"","payload":"false","payloadType":"bool","topic":"","x":319,"y":218,"wires":[["61a8669.9179598"]]},{"id":"61a8669.9179598","type":"function","z":"4ec0caef.1d59ac","name":"analyze message","func":"\n\n// initialize variable as "" if it don't exist\nvar station1 = context.get('station1')||"";\n\nif (msg.topic==="1") {\n station1=msg.payload\n}\n\n// store the value back\ncontext.set('station1',station1);\n\n\nif (msg.payload===false) {\n msg.payload=context.get('station1');\n return msg;\n} \n\n \n","outputs":1,"noerr":0,"x":515.5,"y":218,"wires":[["f26ba179.aaa478"]]},{"id":"65c46ea7.2fbe9","type":"inject","z":"4ec0caef.1d59ac","name":"","topic":"","payload":"Default text","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":185.5,"y":160,"wires":[["a444821b.ba15c8"]]},{"id":"f26ba179.aaa478","type":"debug","z":"4ec0caef.1d59ac","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":705.5,"y":218,"wires":},{"id":"9b65de7c.212788","type":"ui_group","z":"","name":"Save text","tab":"b0f1363e.50c5c8","disp":true,"width":"6","collapse":false},{"id":"b0f1363e.50c5c8","type":"ui_tab","z":"","name":"test","icon":"dashboard","disabled":false,"hidden":false}]
bye
Hi your solution won't work for other users as the forum will change some parts of the code.
Always put code between three ticks
my code here
I'm sure that @Grizzly's flow would work, but you could also try this:
[{"id":"7fc6f8d9.8a57c","type":"q-gate","z":"1840f36c.5e3cc5","name":"","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","maxQueueLength":"1","keepNewest":true,"x":510,"y":120,"wires":[["ecf16095.5a10b"]]},{"id":"d59a26f1.30f738","type":"inject","z":"1840f36c.5e3cc5","name":"","topic":"","payload":"default text","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":180,"y":120,"wires":[["bd6db65b.de98e"]]},{"id":"bd6db65b.de98e","type":"ui_text_input","z":"1840f36c.5e3cc5","name":"Text","label":"input","tooltip":"","group":"c925f0a1.c2066","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"300","topic":"","x":350,"y":120,"wires":[["7fc6f8d9.8a57c"]]},{"id":"ecf16095.5a10b","type":"debug","z":"1840f36c.5e3cc5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":670,"y":120,"wires":[]},{"id":"c3211e88.698d08","type":"ui_button","z":"1840f36c.5e3cc5","name":"","group":"c925f0a1.c2066","order":2,"width":0,"height":0,"passthru":true,"label":"Save","tooltip":"","color":"","bgcolor":"","icon":"","payload":"trigger","payloadType":"str","topic":"control","x":350,"y":160,"wires":[["7fc6f8d9.8a57c"]]},{"id":"8760e8be.395cd","type":"inject","z":"1840f36c.5e3cc5","name":"","topic":"control","payload":"trigger","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":160,"wires":[["c3211e88.698d08"]]},{"id":"40b2d424.4b1ecc","type":"inject","z":"1840f36c.5e3cc5","name":"","topic":"","payload":"hello world","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":80,"wires":[["bd6db65b.de98e"]]},{"id":"c925f0a1.c2066","type":"ui_group","name":"Group 1","tab":"f1dc1ca1.c1457","order":1,"disp":true,"width":6},{"id":"f1dc1ca1.c1457","type":"ui_tab","z":"","name":"Text-Button","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
The node labelled q-gate is node-red-contrib-queue-gate, and it should do the job without any coding.
What does the q-gate node do that the change node and a flow variable couldn't?
E.g...
  • Text node --> change node (copy msg.payload to flow.text)
  • Button node --> change node (copy flow.text to msg.payload) --> debug node
In this case, not a lot. Only that you can deploy as many instances as you want without having to edit each one to define a unique flow variable. If you check the README, you'll see that in general the node has a fair bit of flexibility.
I was just curious. I try not to add too many extra nodes when something built in can handle it. Cheers.
Understood. I wrote node-red-contrib-simple-gate for my own use and only published it and a couple of related nodes a year or more later, because there seemed to be some interest on this forum. I don't think many people use them.
