I have a remote ESP32 system controlling a number of devices from Dashboard via MQTT. All functionality (thus far) is operating as designed. I have also duplicated the ESP system (without the connected devices) that I have been doing additions/modifications/fixes to the ESP software. However, I can't run the remote system and the development system at the same time (presumably) so I have to take the active remote system offline while I work on the development system. What should I do to enable me to run both at once - Dashboard changes? ESP software changes? . I feek I should know how, but can't seem to get my head pointed in the right direction. Look forward to any suggestions. Cheers
What is it that stops you running them both at the same time?
How are you handling the MQTT 'topics' ?
Are the remote ESP32 systems subscribing to the same topic?
I have a number of remote ESP32 systems and use this topic structure...
msg.topic = basenet/${baseID}/${nodeID}/directives;
I can configure each remote system to subscribe to a specific topic like this..
basenet/station_1/node_6/directives //So it only reacts to that topic
Or use the wildcard '+' like this...
basenet/station_1/+/directives
NOTE:
You do realise each client connecting to the broker must have a unique client ID string.
If two or more systems have the same Client ID - a system will get disconnected from the broker - which maybe what is happening in your situation.
EDIT:
MQTT topics are a key part of organizing messages, especially when you have multiple systems or devices to control. Using a well-structured topic hierarchy makes your system scalable, maintainable, and easy to debug.
MQTT topics are hierarchical strings separated by slashes (/):
home/livingroom/light
home/kitchen/temperature
factory/machine1/status
Each level represents a category or a subsystem. Clients subscribe to topics to receive messages, and publish to topics to send commands or updates.
<location>/<system>/<device>/<command_or_data>
Hello David,
Very nice of you to respond so quickly.
Firstly, I am a forum novice and thought as I write to you whether I should reply on the forum?? Your thoughts would be welcome.
As for the content of your response:
- I have implemented the MQTT side of things in the simplest possible way (I’m using Pi Zero for the server)
- And yes, both the active system and the development system do subscribe to the same topic – I was wondering about that, especially as I want to run exactly the same code on both the active and development systems (to ensure when uploading any changed code would operate exactly the same way)
- I’m sorry to admit that I have on idea about your use of ‘basenet’ – what it is for, how is it used etc, etc. I will endeavour to find out in the coming days.
- Is the ‘code’ you have shown in the MQTT server or each of any remote ESP32’s – or both?
Again, thank you for replying and hope to hear from you again.
Cheers
Steve Vardy
Don't worry - basenet is just the name I gave to the network of my remote devices.
I have the name 'homenet' for devices around my home and garden.
It might worth typing something like the following into ChatGPT...
"can you tell me how to use a topic structure with MQTT as I have multiple systems to control ?"
The results you get should prove useful.
What do you mean by remote - Does the ESP32 connect to your MQTT broker over the internet, or are they on the same wifi network?
What mqtt topic structure do you use?
The systems only connect on the same wifi network.
Your question relating to topic structure exposes me to the fact that I setup the system from examples on the web and don't really understand the details.
I have the MQTT server running on a Pi Zero and set it up 'copy and paste' style from an example on the web - and at the time put the necessary 'unique' information into it. I'm struggling to remember the detail and can't locate the code at the moment.
Can you please expand what you mean when you refer to the 'topic' structure?
Do you mean something like this?
Building-A1
- Security
- -Lighting
- Outside
- Front
- Back
- -Sensors
- Smoke
- PIRs
- Workshop
- Store
- Doors
- Road
- Carpark
The way MQTT works is that a device "publishes" a message by sending it to the MQTT broker (we usually call it an mqtt broker rather than a server) using a topic and a value.
The broker will send the message on to any device which has "subscribed" to the topic.
Examples of topics might be "live/ethernet/ip" or "development/wifi/ssid"
This hierarchy of classification, separated by slashes, is what I meant by the topic structure.
Your list might well translate into topics such as "live/sensor/pir/workshop"
There is a really good series of short videos explaining MQTT at https://www.youtube.com/watch?v=jTeJxQFD8Ak. I suggest you watch them to understand MQTT.
There is an MQTT broker Aedes which you can install in Node-red. If you are currently using this, I urge you to look at the stand-alone broker Mosquitto. It runs very well on a Raspberry Pi and has all the latest features.
