Your example has KDY=6C; KT0=52F3
Those are hexadecimal numbers which are the equivalent of 108 and 21235 in decimal. If those are 10 times the required answer then that would give 10.8 and 2123.5. Are those the correct values? I notice that KT0 is not mentioned in the code snippet you posted.
