Help converting buffer to string encoding not matching debug output
I can't seem to get a buffer to convert into a string like the debug node is showing.
My buffer is:
[64,242,199,249,162,6]
The desired string is:
@òÇù¢
The string i'm getting is:
@rGy"
The buffer for the string I'm getting is:
[64,86,69,121,34,6]
I'm using msg.payload = msg.payload.toString("ascii") to convert the buffer and I have tried all the different encoding option I could find. It seems like only certain characters are converting properly.
2023-05-12_10-13-39
try
msg.payload = String.fromCharCode(...msg.payload);
Thank you!
