Hi All,
I've the code below. the python shell is local. If I want to change it to a remote python, how should I do?
const status = require('./status.js')
const {spawn} = require('child_process')
//use 'python3' on linux and 'python' on anything else
const pcmd = process.platform === 'linux' ? 'python3' : 'python'
//initialize child process
const initProc = (node) => {
if (node.proc == null){
node.proc = spawn(pcmd, [node.file], ['pipe', 'pipe','pipe'])
//handle results
node.proc.stdout.on('data', (data) => {
node.status(status.DONE)
try{
node.msg.payload = JSON.parse(data.toString())
catch(err){
node.msg.payload = data.toString()
var msg = node.msg
if(node.wires.length > 1){
msg = [node.msg, null]
node.send(msg)
//handle errors
node.proc.stderr.on('data', (data) => {
node.status(status.ERROR)
try{
catch(err){
var msg = node.msg
msg = [null, node.msg]
node.send(msg)
//handle crashes
node.proc.on('exit', () => {
node.proc = null
//send node configurations to child
node.proc.stdin.write(JSON.stringify(node.config) + '\n')
//send payload as json to python script
const python = (node) => {
initProc(node)
node.proc.stdin.write(JSON.stringify(node.msg.payload) + '\n')
module.exports = {
//parse string containing comma separated integers
listOfInt: (str) => {
var ints = null
try{
ints = str.replace(' ', '').split(',').map((n) => parseInt(n))
if(ints.some(isNaN)){
ints = null
finally{
return ints
//initialize node
run: (RED, node, config) => {
RED.nodes.createNode(node, config)
node.status(status.NONE)
node.proc = null
node.msg = {}
initProc(node)
//process message
const handle = (msg) => {
node.status(status.PROCESSING)
node.msg = msg
if(node.topic != undefined){
node.msg.topic = node.topic
//send to python child
python(node)
//handle input
node.on('input', (msg) => {
//if the node requires preprocessing of message, call preMsg
if(node.preMsg != undefined){
node.preMsg(msg, handle)
else{
handle(msg)
//when node is closed, kill child process
node.on('close', (done) => {
if(node.proc != null){
node.proc.kill()
node.proc = null
done()
