[{"id":"d3990ea58af4b54b","type":"ui_dropdown","z":"5b623fd31ca86a42","name":"","label":"","tooltip":"","place":"Select option","group":"6339e2ead216512f","order":1,"width":"8","height":"2","passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":465,"y":2300,"wires":[["d185ed3ec209d9ab","6721c09082dc906f"]]},{"id":"22b510d60b1dc7ef","type":"change","z":"5b623fd31ca86a42","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"[\"Option 1\",\"Option 2\",\"Option 3\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":305,"y":2300,"wires":[["d3990ea58af4b54b"]]},{"id":"98ae0c1f141b6758","type":"inject","z":"5b623fd31ca86a42","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":2300,"wires":[["22b510d60b1dc7ef"]]},{"id":"d185ed3ec209d9ab","type":"switch","z":"5b623fd31ca86a42","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Option 1","vt":"str"},{"t":"eq","v":"Option 2","vt":"str"},{"t":"eq","v":"Option 3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":625,"y":2300,"wires":[["a4e2022d1058d45c"],["ff9da100f6eadf1a"],["c0e84872d92b02a4"]]},{"id":"a4e2022d1058d45c","type":"change","z":"5b623fd31ca86a42","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"[\"Option 1-1\",\"Option 1-2\",\"Option 1-3\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":2275,"wires":[["b26528bc02725907"]]},{"id":"ff9da100f6eadf1a","type":"change","z":"5b623fd31ca86a42","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"[\"Option 2-1\",\"Option 2-2\",\"Option 2-3\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":2300,"wires":[["b26528bc02725907"]]},{"id":"c0e84872d92b02a4","type":"change","z":"5b623fd31ca86a42","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"[\"Option 3-1\",\"Option 3-2\",\"Option 3-3\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":2325,"wires":[["b26528bc02725907"]]},{"id":"b26528bc02725907","type":"ui_dropdown","z":"5b623fd31ca86a42","name":"","label":"","tooltip":"","place":"Select option","group":"6339e2ead216512f","order":1,"width":"8","height":"2","passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":985,"y":2300,"wires":[["6721c09082dc906f"]]},{"id":"6721c09082dc906f","type":"ui_toast","z":"5b623fd31ca86a42","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":965,"y":2225,"wires":[]},{"id":"6339e2ead216512f","type":"ui_group","name":"Group 2","tab":"5e0dd10e66fdea95","order":2,"disp":false,"width":"30","collapse":false,"className":""},{"id":"5e0dd10e66fdea95","type":"ui_tab","name":"TEST","icon":"dashboard","order":9,"disabled":false,"hidden":false}]
May be like this ?
