How to detect specific dates (daylight savings) with cron+ node
I know it should be easy, but I'm not that smart.
I want to get cron+ (as an example) to tell me when 2 events happen.
Daylight Savings - Start and Daylight Savings - End
Starting: 02:00 First Sunday of October.
End: 02:00 First Sunday of April.
The exact time is not essential.
This is the best I can do so far:
0 0 9 1,7 OCT SUN *
But that isn't showing me what I want in it's decoder pop up.
Its saying October 1 to 7 and on Sunday.
:confused:
06:00 would suffice. But I don't know how to make the template to give that.
Thanks in advance.
OK, is this it?
[{"id":"7b296738.fd4788","type":"cronplus","z":"65c9b63cb09879a0","name":"Monthly","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output1","outputs":1,"options":[{"name":"schedule1","topic":"schedule1","payloadType":"str","payload":"SUMMER","expressionType":"cron","expression":"0 0 9 * OCT SUN#1 * ","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"},{"name":"schedule2","topic":"schedule2","payloadType":"str","payload":"NORMAL","expressionType":"cron","expression":"0 0 9 * APR SUN#1 * ","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":3420,"y":170,"wires":[[]]}]
Just want to check I understand it all.
0 0 2 ? 10 SUN#1 * - Starting: 02:00 First Sunday of October
0 0 2 ? 4 SUN#1 * - End: 02:00 First Sunday of April.
There is an example that would get you close...
Also, there is the expression builder
UDu0D3Msjt
Thanks.
In the node example I posted the ? was a *.
Yet it says it will do the same....
Would you mind looking at the node I posted and check that - please.
Just to follow on that...
Watching your movie....
easy expression maker... Nice. But if I have the basic thing I want and then click on it, I get a very different screen.
(Ok, not your node - is it? - but that also is throwing me)
Screenshot from 2021-10-03 19-11-36
Screenshot from 2021-10-03 19-11-45
Screenshot from 2021-10-03 19-11-50
(Ok.... Not the latest version of the node.... Updating now.)
Only to save me (maybe) having to repost.....
Hang on.
* means every day and ? means don't care/unspecified
So when you use * it will execute every day - HOWEVER - in this instance, * and ? are irrelevant because SUN#1 will limit the schedule to the first Sunday.
I am stupid and the subtle difference isn't getting through.
Rock is not exactly accommodating to absorbing things. :wink:
Again: Thanks.
Ah! When the pop up opens, I have to select MONTH in the one I get/see/showed you.
Then it all falls into place.
