How to disable a button from another button
Hi all
I am just starting to play with Nodered and ESP32 so I apologise if this is a basic question but I have to start somewhere !!.
I have got 2 flows the same the top one controls an antenna switch turning it on and off, the bottom one switches between 2 different feed lines ( on or off). What I want to do is disable the bottom button (greyed out) when the top one of switched off, but have it active when the top one is on. Hope this makes some sense. hope i have uploaded this correctly. Thanks for looking Paul
        "id": "331a4c46c0b94a7d",
        "type": "function",
        "z": "494453487fce66d1",
        "name": "ant 1",
        "func": "\nlet payload=msg.payload;\nlet state=context.get(\"state\");\nif(msg.topic==\"init\")\n{\n    state = \"open\";\n    msg.payload = \"off\";\n    msg.background = \"grey\";\n    msg.label = \"Press to Start\";\n    msg.myicon = \"fa-toggle-off\";\n    msg.topic=\"control\";\n    context.set(\"state\", \"closed\");\n    return msg;\n}\n//toggle\nif (typeof state == \"undefined\" || state==\"open\")\n{\n//state=\"open\";\nmsg.payload= \"off\";\nmsg.background = \"grey\";\nmsg.label = \"Antenna 1 off\";\nmsg.myicon = \"fa-toggle-off\";\nstate=\"closed\";\n\n}\nelse if (typeof state == \"undefined\" || state == \"closed\") {\n//state = \"close\";\nmsg.payload= \"on\";\nmsg.background = \"green\";\n    msg.label = \"Antenna 1 selected\";\nmsg.myicon=\"fa-toggle-on\";\nstate=\"open\";\n\n}\ncontext.set(\"state\",state);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "// Code added here will be run once\n// whenever the node is started.\ncontext.set(\"state\", \"closed\");",
        "finalize": "",
        "libs": [],
        "x": 470,
        "y": 310,
                "453afee6601230b9",
                "106fb70acae08d04",
                "6d3971975772ae72"
        "id": "4caa7eb9dbc9a685",
        "type": "ui_button",
        "group": "b2f76e121f1e3856",
        "order": 1,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "{{topic}}",
        "tooltip": "",
        "color": "",
        "bgcolor": "{{background}}",
        "className": "",
        "icon": "{{myicon}}",
        "payload": "off",
        "payloadType": "str",
        "topic": "relay/device1",
        "topicType": "str",
        "x": 370,
        "y": 420,
                "331a4c46c0b94a7d"
        "id": "453afee6601230b9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "label",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 190,
        "y": 420,
                "4caa7eb9dbc9a685"
        "id": "106fb70acae08d04",
        "type": "mqtt out",
        "topic": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "f308ad008433f052",
        "x": 730,
        "y": 420,
        "id": "9e793e4141ca5944",
        "type": "function",
        "name": "ant 1",
        "func": "\nlet payload=msg.payload;\nlet state=context.get(\"state\");\nif(msg.topic==\"init\")\n{\n    state = \"open\";\n    msg.payload = \"off\";\n    msg.background = \"grey\";\n    msg.label = \"Press to Start\";\n    msg.myicon = \"fa-toggle-off\";\n    msg.topic=\"control\";\n    context.set(\"state\", \"closed\");\n    return msg;\n}\n//toggle\nif (typeof state == \"undefined\" || state==\"open\")\n{\n//state=\"open\";\nmsg.payload= \"off\";\nmsg.background = \"red\";\nmsg.label = \"red channel\";\nmsg.myicon = \"fa-toggle-off\";\nstate=\"closed\";\n\n}\nelse if (typeof state == \"undefined\" || state == \"closed\") {\n//state = \"close\";\nmsg.payload= \"on\";\nmsg.background = \"green\";\n    msg.label = \"green channel\";\nmsg.myicon=\"fa-toggle-on\";\nstate=\"open\";\n\n}\ncontext.set(\"state\",state);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "finalize": "",
        "libs": [],
        "x": 490,
        "y": 520,
                "3bdbe08c023fae13",
                "106fb70acae08d04",
                "6d3971975772ae72"
        "id": "083ed8df6a73e522",
        "order": 1,
        "width": "4",
        "height": "1",
        "passthru": false,
        "tooltip": "",
        "color": "",
        "className": "",
        "payload": "off",
        "topicType": "str",
        "x": 410,
        "y": 630,
                "9e793e4141ca5944"
        "id": "3bdbe08c023fae13",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "label",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 230,
        "y": 630,
                "083ed8df6a73e522"
        "id": "6d3971975772ae72",
        "type": "debug",
        "name": "debug 6",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 800,
        "y": 320,
        "id": "b2f76e121f1e3856",
        "type": "ui_group",
        "name": "antenna on/off",
        "tab": "4f762449cfcb3fcf",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": false,
        "className": ""
        "id": "f308ad008433f052",
        "type": "mqtt-broker",
        "name": "localhost",
        "broker": "localhost",
        "port": 1883,
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": 4,
        "keepalive": 60,
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "4f762449cfcb3fcf",
        "type": "ui_tab",
        "icon": "dashboard",
        "order": 6,
        "disabled": false,
        "hidden": false
Welcome to the forum @g0heu.
You can enable/disable your second button by passing it msg.enabled true/false.
So in your first function set eg msg.enablebutton2 = true (or false)
And use a change node to move this value into msg.enabled before feeding it into the second button.
(Sorry I had to rearrange your flow and rename some nodes so it made sense to me)
Note that there is a replacement for the node-red-dashboard component that you are using, @flowfuse/node-red-dashboard. It's relatively new and not as beginner-friendly unfortunately.
hi jbudd
thanks for the replay
i have added msg.enablebutton2 = true into the top of the first funtion and setup the change node as you said i think, i am getting a error in the change node as shown. when i select the "antenna select" button it greys out the other button but it still functions
thanks
Hi @g0heu that is not right.
If you are new to node-red, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
It covers the change node and much more.
Regarding this immediate issue - read the change node form rules like a story: "Set" "msg.enabled" "to the value of" "msg.enablebutton2"
thanks Steve
I will have a look at the video's
your info on the issue has cleared the error but the second button is still not disabled when the first switched off
in the debut windows coming out of the change node i am getting
enablebutton2: false
enable: false
thanks
Details are important.
here is the complete flow
thanks
        "id": "827719579c3a4aaa",
        "type": "function",
        "z": "74964b6a7a37dbbc",
        "name": "ant 1 on/off",
        "func": "\nlet payload=msg.payload;\nlet state=context.get(\"state\");\n\nif(msg.topic==\"init\")\n{\n    state = \"open\";\n  \n    msg.payload = \"off\";\n    msg.background = \"grey\";\n    msg.label = \"Press to Start\";\n    msg.myicon = \"fa-toggle-off\";\n    msg.topic=\"control\";\n    context.set(\"state\", \"closed\");\n    return msg;\n}\n//toggle\nif (typeof state == \"undefined\" || state==\"open\")\n{\n//state=\"open\";\nmsg.payload= \"off\";\n\nmsg.background = \"grey\";\nmsg.label = \"Antenna 1 off\";\nmsg.myicon = \"fa-toggle-off\";\nmsg.enablebutton2 = false\nmsg.enable = false\nstate=\"closed\";\n\n}\nelse if (typeof state == \"undefined\" || state == \"closed\") {\n//state = \"close\";\nmsg.payload= \"on\";\n\nmsg.background = \"green\";\n    msg.label = \"Antenna 1 selected\";\nmsg.myicon=\"fa-toggle-on\";\nstate=\"open\";\n\n}\ncontext.set(\"state\",state);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "finalize": "",
        "libs": [],
        "x": 730,
        "y": 140,
                "66b26a896a280d5d",
                "b4bede351dcffe4a",
                "26930ccca786f20c"
        "id": "6168e8180b7d6e14",
        "order": 1,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "ant1 on/off",
        "tooltip": "",
        "color": "",
        "className": "",
        "payload": "false",
        "payloadType": "bool",
        "topicType": "str",
        "x": 450,
        "y": 140,
                "827719579c3a4aaa",
                "c80ab9298e6d89bd"
        "id": "66b26a896a280d5d",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "label",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 270,
        "y": 140,
                "6168e8180b7d6e14"
        "id": "b4bede351dcffe4a",
        "type": "mqtt out",
        "topic": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1050,
        "y": 260,
        "id": "fef9af0080e511b5",
        "type": "function",
        "name": "Blue or orange",
        "func": "\nlet payload=msg.payload;\nlet state=context.get(\"state\");\nif(msg.topic==\"init\")\n{\n    state = \"open\";\n    msg.payload = \"off\";\n    msg.background = \"blue\";\n    msg.label = \"Press to Start\";\n    msg.myicon = \"fa-toggle-off\";\n    msg.topic=\"control\";\n    context.set(\"state\", \"closed\");\n    return msg;\n}\n//toggle\nif (typeof state == \"undefined\" || state==\"open\")\n{\n//state=\"open\";\nmsg.payload= \"off\";\nmsg.background = \"blue\";\nmsg.label = \"red channel\";\nmsg.myicon = \"fa-toggle-off\";\nstate=\"closed\";\n\n}\nelse if (typeof state == \"undefined\" || state == \"closed\") {\n//state = \"close\";\nmsg.payload= \"on\";\nmsg.background = \"orange\";\n    msg.label = \"green channel\";\nmsg.myicon=\"fa-toggle-on\";\nstate=\"open\";\n\n}\ncontext.set(\"state\",state);\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 260,
                "0e5850189d63e5a1",
                "b4bede351dcffe4a"
        "id": "d713e4905614a725",
        "order": 1,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "Ant1 -- Blue or orange",
        "tooltip": "",
        "color": "",
        "className": "",
        "payload": "",
        "topic": "relay/device5",
        "topicType": "str",
        "x": 480,
        "y": 260,
                "fef9af0080e511b5",
                "26930ccca786f20c"
        "id": "0e5850189d63e5a1",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "label",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 270,
        "y": 260,
                "d713e4905614a725"
        "id": "c80ab9298e6d89bd",
        "type": "change",
        "name": "button enable",
        "rules": [
                "t": "set",
                "p": "enable",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 420,
        "y": 200,
                "d713e4905614a725",
                "26930ccca786f20c"
        "id": "26930ccca786f20c",
        "type": "debug",
        "name": "debug 8",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 1040,
        "y": 180,
        "type": "ui_group",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": false,
        "className": ""
        "port": 1883,
        "clientid": "",
        "usetls": false,
        "keepalive": 60,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "type": "ui_tab",
        "order": 6,
        "disabled": false,
        "hidden": false
Take a slow and careful look at your change node.
Pay special attention to the names of the message properties you are working on.
If you cannot see the difference then you are not reading what is there, you are reading what you think is there.
hi jbudd
I am sorry i just cant see it ????
i think i have spent to much time trying to work it out
give me a clue ???
thanks
msg.enable versus msg.enabled
thanks Colin
I just couldnt see it !!!! been looking to long !!!
thanks
I think you had better thank @jbudd for identifying the problem it in the first place.
hi Colin
yes thanks to jbudd well spotted
evan after looking at the messages i still didnt see it
thanks again for your help
cheers
