How to disable specific nrlint rule?
When using nrlint, it doesn't take into account module import (as reported here: Similar to · Issue #44 · node-red/nrlint
It is a simple click in the editor to ignore, adding this to description of node or flow:
// nrlint function-eslint:off
However, that disables all rules. How can we disable specific rules? Like the import rule. Further more, it would be a great option to be able to ignore linting for specific lines with comments. Is that possible?
Maybe with:
// nrlint eslint-disable-line
Add the rule to disable/ignore after // nrlint
The suggestion from @GogoVega is close - don't add the nrlint bit at the start, otherwise eslint (the JavaScript linter we use) won't 'see' it.
To disable linting on an individual line:
// eslint-disable-line
To disable linting of all the code in the node:
// eslint-disable
Not sure but the rule should be no-undef.
Glorious, thanks!
