How to display JSON Data in a Gauge?
Hi I am new to node-red and have already figured out how to get the data from a JSON website in to node-red using inject-node + http-request-node & the debug-node. Also figured out how to extract specific data contained within the JSON object payload with debug-node.
So now I want to use a Gauge (i downloaded the dashboard-extentions already) to display values between 0-100 from that JSON page.
Can someone give me a hint?
Simon
How to do it depends on whether you are using the original node-red-dashboard, @flowfuse/node-red-dashboard or some other dashboard extension.
Easier to give a hint if you include a sample of your json object. Post as data, not a screen capture please.
Hi Thanks!
I am using the standard "node-red-dashboard 3.6.5"
And I am not sure if this is what you need - I just copied to clipboard & pasted here because as a new user I am not allowed to upload exported JSON-files :frowning:
        "id": "1dee7bec5e83924f",
        "type": "debug",
        "z": "9311b4c7d2d6c16c",
        "name": "Nur Rapid",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload[\"machine data\"].RapidOverrideManualRapidOverride",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 660,
        "y": 360,
        "id": "a4872b60eeaa7066",
        "type": "http request",
        "method": "GET",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "http://192.168.178.254/json/json",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 450,
        "y": 260,
                "2efc53e5b47c07a9",
                "1dee7bec5e83924f"
        "id": "44c4b48f434623ff",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 260,
        "y": 120,
                "a4872b60eeaa7066"
        "id": "2efc53e5b47c07a9",
        "type": "debug",
        "name": "Alles",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "statusVal": "",
        "x": 650,
        "y": 280,
node-red-dashboard uses a javascript library which is no longer supported. Since you are new to Node-red, it would be wiser to use it's replacement @flowfuse/node-red-dashboard. It's very different and time spent learning the original is probably wasted.
No, I meant the data which shows up in the debug node. There is a "copy value" button which shows up when you hover the mouse over the debug message
And to paste it here, click on the preformatted text button </> and paste your data (or code) between the two lines of backticks.
Hi there - okay, so I installed the suggested Dashboard successfully.
Then I copied the data in the debug node.
Please disregard the data from my original post, for testing-convenience I am now using other data which looks different but comes from a JSON page and looks like this:
{"message":"success","iss_position":{"longitude":"18.5899","latitude":"-28.4088"},"timestamp":1746517625}
I want to learn how to get this data in to a chart or gauge.
Fully aware that it doesn't make sense to have longitude latitude or timestamp in a chart or gauge, but I am just using these values to practise, being easily accessible here:
http://api.open-notify.org/iss-now.json
Thank you!
You just need to move the value you want into msg.payload and feed it to the chart. So if you wanted to chart the longitude, for example, you would need a Change node that Moves msg.payload.iss_position.longitude To msg.payload.
As you are just starting with node-red I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
By the way, do not get confused over the term JSON. A JSON object is a string representation of a javascript object. A javascript object is not JSON, it is a javascript object.
This post and this post should help to clarify the difference between Javascript objects and JSON.
Hi, I read the articles and watches the first few of the YouTube vids - thank you!
I created a change node and pot in what I think you meant, Colin.
It appears that I managed to get the longitude in to the desired msg.payload:
7.5.2025, 13:36:28node: debug 2msg.payload : string[8] "-52.6729"
How do I inject this in to a gauge then?
In the gauge settings, I can only see that you can change its appearance.
Just connect the Change node to the gauge.
Obviously, if you want to show a negative number, then make sure that the range of the gauge is setup appropriately, -100 to +100 for example.
Got it°!!!!!!!
Now I have what I need to get going and thank you so much!
On the way I found this one which helped me a lot - maybe for someone reading this:
Thanks Colin and jbudd!
