I'm trying to dynamically enter com details for a serial port. While msg.baudrate is working while injected. Msg.port cannot be injected into the node. Serial port details if not explicitly mentioned in the serial request node when deployed is showing type error. Is my approach correct or is it not possible to implement dynamic msg.port config
Hi - you are correct - It is currently not possible to change the port dynamically.
