How to enable or disable UI button when message to button input triggers button feature set? In the old dashboard you could do this by passing msg.enabled false to disable, and msg.enabled true to enable, and deleting msg.payload in both cases. But in the new dashboard 2.0, this does not work?
This does seem to work for me (NR 4.1.0, FFDB 1.29.0), at least my button turns ugly:
According to https://dashboard.flowfuse.com/nodes/widgets/ui-control#enable-disable you should be able to disable a widget by passing a message to a ui-control node as below, but this doesn't work.
msg.payload = {
pages: {
enable: ['<Page Id>''],
disable: ['<Page Id>']
groups: {
enable: ['<Group Id>'],
disable: ['<Group Id>']
widgets: {
enable: ['<Widget Id>'],
disable: ['<Widget Id>']
It works for me. Make sure you are inject boolean true/false, not string. Test flow:
[{"id":"12e8ed66865153ba","type":"inject","z":"997da33a0beedade","name":"disable","props":[{"p":"enabled","v":"false","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":7120,"wires":[["eb015f507335250d"]]},{"id":"20bde1e7729dce51","type":"inject","z":"997da33a0beedade","name":"enable","props":[{"p":"enabled","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":7080,"wires":[["eb015f507335250d"]]},{"id":"eb015f507335250d","type":"ui-button","z":"997da33a0beedade","group":"4f87bd59a15b847e","name":"test button","label":"test button","order":0,"width":"2","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":450,"y":7100,"wires":[[]]},{"id":"4f87bd59a15b847e","type":"ui-group","name":"test","page":"c6ff182a4185f2f2","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"c6ff182a4185f2f2","type":"ui-page","name":"Test page","ui":"ID-BASE-1","path":"/testpage","icon":"home","layout":"grid","theme":"c4cba76c368d7996","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":3,"className":"","visible":"true","disabled":"false"},{"id":"ID-BASE-1","type":"ui-base","name":"Dashboard","path":"/dashboard","appIcon":"","includeClientData":false,"acceptsClientConfig":["ui-control","ui-notification","ui-gauge-classic"],"showPathInSidebar":false,"headerContent":"page","titleBarStyle":"default","showReconnectNotification":false,"notificationDisplayTime":"1","showDisconnectNotification":true,"allowInstall":true},{"id":"c4cba76c368d7996","type":"ui-theme","name":"Test theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}},{"id":"973001a83d7b2ca3","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.29.0"}}]
I think that is an error in the docs.
No I am wrong, there is code in the dashboard source that says it does what the docs say, so this is a bug. @jbudd could you submit an issue please?
I saw where you said that in another thread Colin, which was why I was confident in my experiment showing this doesn't work for widgets.
However, I couldn't get it to disable a page either so maybe I misunderstood the documentation, or I might have omitted the s of pages?
Also I had to put double quotes around all the keys and array elements in that js object in order to inject it, perhaps that broke the ui-update.
I believe that it has worked for groups and pages. I haven't tested it recently though.
so I found that msg.enabled true/or false does still work for some nodes, some times, i.e. the new buttons in dashboard 2.0... but does not seem to work for tables... if memory serves, have to validate. but even deleting the msg.payload when sending msg.enabled to the new buttons, has odd results as I noted in my original post/question?
Could you submit an issue for this please.
Can you describe what problem you are still seeing with buttons? Your original post just says it doesn't work?
