Hello.
Using several flows to read data from Modbus device -> data are stored in influxdb.
Using CronePlus or inject node to trigger the read with a modbus-getter node. Read durations are different -> some 15s / every 15min / 1 time per 24h
Issue:
Getting problems when i would like to collect the data 1x / 24h or every 15min - looks like the device is in sleep or not ready.
Therefore I would like to implement a function/query to secure the data are read and stored in influxdb.
How could I integrate a function or something else to check?
Please - need some help for a smart way.
Thx.
Following flow as an example.
"id": "c454cc2a06e55e7e",
"type": "tab",
"label": "Flow 5",
"disabled": false,
"info": "",
"env": []
"id": "5f544df279f3bdc4",
"type": "modbus-getter",
"z": "c454cc2a06e55e7e",
"name": "Tiefenbohrung_EIN_AUS",
"showStatusActivities": false,
"showErrors": false,
"logIOActivities": false,
"unitid": "1",
"dataType": "HoldingRegister",
"adr": "529",
"quantity": "4",
"server": "82be51f24ff6f9e9",
"useIOFile": false,
"ioFile": "",
"useIOForPayload": false,
"emptyMsgOnFail": true,
"keepMsgProperties": false,
"x": 610,
"y": 240,
"2861e297a45dbdcd"
"id": "2861e297a45dbdcd",
"type": "buffer-parser",
"data": "responseBuffer.buffer",
"dataType": "msg",
"specification": "spec",
"specificationType": "ui",
"items": [
"type": "floatle",
"name": "Tiefenbohrung_Ein",
"offset": 0,
"length": 1,
"offsetbit": 0,
"scale": "1",
"mask": ""
"type": "floatle",
"name": "Tiefenbohrung_Aus",
"offset": 4,
"length": 1,
"offsetbit": 0,
"scale": "1",
"mask": ""
"swap1": "swap16",
"swap2": "",
"swap3": "",
"swap1Type": "swap",
"swap2Type": "swap",
"swap3Type": "swap",
"msgProperty": "payload",
"msgPropertyType": "str",
"resultType": "value",
"resultTypeType": "output",
"multipleResult": true,
"fanOutMultipleResult": true,
"setTopic": true,
"outputs": 2,
"x": 870,
"y": 240,
"ffc01717643e7f2c",
"fadf47f850783c4a"
"05605fca6b978349",
"fadf47f850783c4a"
"id": "ffc01717643e7f2c",
"type": "debug",
"name": "Tiefenbohrung_EIN",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"targetType": "full",
"statusVal": "payload",
"statusType": "auto",
"x": 1110,
"y": 240,
"id": "05605fca6b978349",
"type": "debug",
"name": "Tiefenbohrung_AUS",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "true",
"x": 1120,
"y": 280,
"id": "fadf47f850783c4a",
"type": "join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "num",
"reduceFixup": "",
"x": 1090,
"y": 200,
"da5112150a27b07c"
"id": "50f6d9dfd3f57599",
"type": "influxdb out",
"influxdb": "52608438d6b07280",
"name": "InfluxDB_Write",
"measurement": "Tiefenbohrung_EIN_AUS",
"precision": "ms",
"retentionPolicy": "",
"database": "test",
"precisionV18FluxV20": "s",
"retentionPolicyV18Flux": "",
"org": "GuE_InfluxDB",
"bucket": "WP_Database",
"x": 1520,
"y": 200,
"id": "1aadfcc9ef44e517",
"type": "cronplus",
"name": "Cron-Plus-Trigger",
"outputField": "payload",
"timeZone": "",
"persistDynamic": false,
"commandResponseMsgOutput": "output1",
"outputs": 1,
"options": [
"name": "TriggerKeinBetriebTrue",
"topic": "TriggerKeinBetriebTrue",
"payloadType": "bool",
"payload": "true",
"expressionType": "cron",
"expression": "*/15 * * * *",
"location": "",
"offset": "0",
"solarType": "all",
"solarEvents": "sunrise,sunset"
"x": 230,
"y": 240,
"5f544df279f3bdc4"
"id": "da5112150a27b07c",
"type": "switch",
"name": "KeinBetrieb_TRUE",
"property": "BetriebszustandArray.KeinBetrieb",
"propertyType": "global",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1310,
"y": 200,
"50f6d9dfd3f57599"
"id": "82be51f24ff6f9e9",
"type": "modbus-client",
"name": "RS232_MOXA_NP5110",
"clienttype": "serial",
"bufferCommands": false,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": true,
"tcpHost": "192.168.100.18",
"tcpPort": "950",
"tcpType": "TCP-RTU-BUFFERED",
"serialPort": "/dev/ttyr00",
"serialType": "RTU-BUFFERD",
"serialBaudrate": "9600",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "100",
"serialAsciiResponseStartDelimiter": "0x3A",
"unit_id": "1",
"commandDelay": "50",
"clientTimeout": "1000",
"reconnectOnTimeout": true,
"reconnectTimeout": "2000",
"parallelUnitIdsAllowed": false
"id": "52608438d6b07280",
"type": "influxdb",
"hostname": "127.0.0.1",
"port": "8086",
"protocol": "http",
"database": "database",
"name": "WP_Database",
"usetls": false,
"tls": "",
"influxdbVersion": "2.0",
"url": "http://localhost:8086",
"rejectUnauthorized": true
