Hi.
I have a json object that I want to extract some value from, but I cant' find the way to do it.
I 'm able to see the entire object in the debug window, but I'm not able to extract what I need and then send it to different dashboard.
Here is what I tried till now :
[{"id":"a5b85e10.ae3ac8","type":"debug","z":"d9e4a171.78ed68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":120,"wires":[]},{"id":"eabf1257.2c0ba","type":"mqtt in","z":"d9e4a171.78ed68","name":"","topic":"/sbms","qos":"2","datatype":"auto","broker":"59a61781.6bb818","x":100,"y":120,"wires":[["96c2d78f.4382e"]]},{"id":"96c2d78f.4382e","type":"json","z":"d9e4a171.78ed68","name":"","property":"payload","action":"","pretty":false,"x":280,"y":120,"wires":[["2a49038.1c9e57c","a5b85e10.ae3ac8"]]},{"id":"2a49038.1c9e57c","type":"switch","z":"d9e4a171.78ed68","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"\"time\"","vt":"str"},{"t":"eq","v":"payload{\"time\":{\"year\":0,\"month\":1,\"day\":3,\"hour\":5,\"minute\":33,\"second\":16},\"soc\":40,\"cellsMV\":[3230,3201,3224,3229,3231,3223,3223,3228],\"tempInt\":20.3,\"tempExt\":18.8,\"currentMA\":{\"battery\":-2037,\"pv1\":32,\"pv2\":0,\"extLoad\":0},\"ad2\":0,\"ad3\":0,\"ad4\":0,\"heat1\":0,\"heat2\":0,\"flags\":{\"OV\":false,\"OVLK\":false,\"UV\":false,\"UVLK\":false,\"IOT\":false,\"COC\":false,\"DOC\":false,\"DSC\":false,\"CELF\":false,\"OPEN\":false,\"LVC\":false,\"ECCF\":false,\"CFET\":true,\"EOC\":false,\"DFET\":true,\"delta\":30}}","vt":"str"},{"t":"eq","v":"\"cellsMV\"","vt":"str"},{"t":"eq","v":"\"tempInt\"","vt":"str"},{"t":"eq","v":"tempExt","vt":"str"},{"t":"eq","v":"currentMA","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":380,"y":200,"wires":[["558bc663.11115"],["83607171.b61ed","3710071e.e172a"],[],["9383e093.ab13d","7ec6d3d5.448c4c"],["fd4f5fe4.2a054","bd5a1d62.773c9"],[]]},{"id":"3710071e.e172a","type":"debug","z":"d9e4a171.78ed68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":160,"wires":[]},{"id":"7ec6d3d5.448c4c","type":"debug","z":"d9e4a171.78ed68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":200,"wires":[]},{"id":"bd5a1d62.773c9","type":"debug","z":"d9e4a171.78ed68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":240,"wires":[]},{"id":"558bc663.11115","type":"debug","z":"d9e4a171.78ed68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":730,"y":140,"wires":[]},{"id":"83607171.b61ed","type":"ui_gauge","z":"d9e4a171.78ed68","name":"","group":"c3ff9b69.9986e","order":0,"width":0,"height":0,"gtype":"gage","title":"SOC","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#b50200","#00e6d5","#8dca38"],"seg1":"20","seg2":"80","x":570,"y":320,"wires":[]},{"id":"9383e093.ab13d","type":"ui_gauge","z":"d9e4a171.78ed68","name":"","group":"c3ff9b69.9986e","order":0,"width":0,"height":0,"gtype":"gage","title":"TempInt","label":"%","format":"{{value}}","min":0,"max":"40","colors":["#b50200","#00e6d5","#8dca38"],"seg1":"20","seg2":"80","x":560,"y":360,"wires":[]},{"id":"fd4f5fe4.2a054","type":"ui_gauge","z":"d9e4a171.78ed68","name":"","group":"c3ff9b69.9986e","order":0,"width":0,"height":0,"gtype":"gage","title":"Tempext","label":"%","format":"{{value}}","min":0,"max":"40","colors":["#b50200","#00e6d5","#8dca38"],"seg1":"20","seg2":"80","x":540,"y":420,"wires":[]},{"id":"59a61781.6bb818","type":"mqtt-broker","name":"","broker":"192.168.1.79","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"c3ff9b69.9986e","type":"ui_group","name":"DefaultSBMS","tab":"fd4b8c75.b67c2","order":3,"disp":true,"width":"6","collapse":false},{"id":"fd4b8c75.b67c2","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
And here is an example of my json object
/sbms {"time":{"year":0,"month":1,"day":1,"hour":0,"minute":40,"second":53},"soc":49,"cellsMV":[3298,3283,3298,3300,3301,3298,3297,3299],"tempInt":22.8,"tempExt":21.1,"currentMA":{"battery":-1018,"pv1":503,"pv2":344,"extLoad":0},"ad2":0,"ad3":0,"ad4":0,"heat1":0,"heat2":0,"flags":{"OV":false,"OVLK":false,"UV":false,"UVLK":false,"IOT":false,"COC":false,"DOC":false,"DSC":false,"CELF":false,"OPEN":false,"LVC":false,"ECCF":false,"CFET":true,"EOC":false,"DFET":true}}
