How to extract values from an Object?
Could you please help me to find out how to get data from an object with variables with special signs ?
msg.payload = msg.payload.SDS0X1."PM2.5";
msg.payload = msg.payload.SDS0X1.[PM2.5];
msg.payload = msg.payload.SDS0X1.'PM2.5';
none of these works ...
Without knowing what the data looks like, it will be hard to help you.
Connect a debug node to what ever is giving you the data. Then open all the levels of the object and paste it to a reply.
Maybe try msg.payload = msg.payload.SDS0X1["PM2.5"];
you either use . or [" "]
Hi @Golonder
This page in the docs shows how you can use the Debug sidebar to find out the path to any element of a message. It will give you the properly formatted expression to access the property.
