Hi there, I want to get data from my Homey, via API.
I have made the flow below, according to this guide:
But as you see in the debug, i only get the homey verson and ID. What am I doing wrong?
Maybe try to set the header like this:
[{"id":"e3a9f717e0dbab8a","type":"http request","z":"94c514c2ac360b08","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://127.0.0.1:1880","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Authorization","keyValue":"","valueType":"msg","valueValue":"token"}],"x":650,"y":640,"wires":[["5e3560e9ef6ea6de"]]},{"id":"845b669fc551b684","type":"inject","z":"94c514c2ac360b08","name":"token from msg","props":[{"p":"token","v":"Bearer <your api key>","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":460,"y":640,"wires":[["e3a9f717e0dbab8a"]]},{"id":"5e3560e9ef6ea6de","type":"debug","z":"94c514c2ac360b08","name":"debug 17","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":640,"wires":[]},{"id":"28ed30cd1ae7351e","type":"http request","z":"94c514c2ac360b08","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://127.0.0.1:1880","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"Authorization","keyValue":"","valueType":"other","valueValue":"Bearer <your api key>"}],"x":650,"y":760,"wires":[["39d0db7f58423862"]]},{"id":"64f769a1b796fd68","type":"inject","z":"94c514c2ac360b08","name":"token from node","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":460,"y":760,"wires":[["28ed30cd1ae7351e"]]},{"id":"39d0db7f58423862","type":"debug","z":"94c514c2ac360b08","name":"debug 18","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":760,"wires":[]},{"id":"e2d9a5f9f8bd91d1","type":"comment","z":"94c514c2ac360b08","name":"or","info":"","x":650,"y":700,"wires":[]}]
Nothing apart from not using the different classes with your http request HomeyAPIV3Local - Homey Web API.
192-168-1-116
Oddly enough that is the way the server can be addressed and is in the example given in the API docs. It's part of a host name and not an IP address!!!
Bit of a frightening address though as it refers to an external domain to access a device internally and who knows what happens if you change the address or two devices have the same one (given lots of home routers default to 192.168.0.0/24 or 192.168.1.0/24 it must happen and be managed somehow).
Just hope it does not use ARP poisoning to determine location!
