I have got several functions, which rely on aavailabel json outputs from fronius inverters.
now already the second time, after a firmware upgrade, some fields in the json output changed. ![]()
the big question: how do I get meaningful output of the functions?
[error] [function:Gen24 + merge] TypeError: Cannot read properties of undefined (reading 'channels')
does not help - the function below has 24 'channels' fields
help is much appreciated. ![]()
var e_total_string1 = parseInt(msg.payload.Body.Data["393216"].channels.PV_ENERGYACTIVE_ACTIVE_SUM_01_U64) || 0;
var e_total_string2 = parseInt(msg.payload.Body.Data["393216"].channels.PV_ENERGYACTIVE_ACTIVE_SUM_02_U64) || 0;
if (!isNaN(parseInt(msg.payload.Body.Data["16252931"].channels.SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64))){
flow.set('OpenDTU.total.YieldTotal.v', parseInt(msg.payload.Body.Data["16252931"].channels.SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64)/1000);
flow.set('OpenDTU.total.YieldTotal.d', 6);
flow.set('OpenDTU.total.Power.v', parseInt(msg.payload.Body.Data["16252931"].channels.SMARTMETER_POWERACTIVE_MEAN_SUM_F64));
flow.set('OpenDTU.total.Power.d', 2);
var e_total_opendtu = ((msg.opendtu == -1) ? (parseInt(msg.payload.Body.Data["16252931"].channels.SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64) || 0) : msg.opendtu);
var e_total = parseInt((e_total_string1 + e_total_string2) / 3600) + msg.symo12_string1 + msg.symo12_string2 + e_total_opendtu + msg.symo5_string1;
var bat_activecharge = parseInt(msg.payload.Body.Data["393216"].channels.BAT_ENERGYACTIVE_ACTIVECHARGE_SUM_01_U64) || 0;
var bat_activedischarge = parseInt(msg.payload.Body.Data["393216"].channels.BAT_ENERGYACTIVE_ACTIVEDISCHARGE_SUM_01_U64) || 0;
var e_importtotal = parseInt(msg.payload.Body.Data["16252928"].channels.SMARTMETER_ENERGYACTIVE_ABSOLUT_PLUS_F64) || 0;
var e_exporttotal = parseInt(msg.payload.Body.Data["16252928"].channels.SMARTMETER_ENERGYACTIVE_ABSOLUT_MINUS_F64) || 0;
var e_consumed = e_total + e_importtotal - e_exporttotal + parseInt((bat_activedischarge - bat_activecharge) / 3600);
global.set('Fronius_Live.E_Total_Gen24_string1', parseFloat(e_total_string1 / 3600));
global.set('Fronius_Live.E_Total_Gen24_string2', parseFloat(e_total_string2 / 3600));
global.set('Fronius_Live.E_Total_Gen24_battchg', parseFloat(bat_activecharge / 3600));
global.set('Fronius_Live.E_Total_Gen24_battdischg', parseFloat(bat_activedischarge / 3600));
var battserial = ''
var battdata = null
if (!isNaN(parseInt(msg.payload.Body.Data["16580608"].channels.COMPONENTS_MODE_ENABLE_U16)) && parseInt(msg.payload.Body.Data["16580608"].channels.COMPONENTS_MODE_ENABLE_U16) == 1) battserial = '16580608';
if (!isNaN(parseInt(msg.payload.Body.Data["16580609"].channels.COMPONENTS_MODE_ENABLE_U16)) && parseInt(msg.payload.Body.Data["16580609"].channels.COMPONENTS_MODE_ENABLE_U16) == 1) battserial = '16580609';
if (battserial != '') battdata = msg.payload.Body.Data[battserial];
return [{ topic: msg.topic, timestamp: msg.timestamp,
e_importtotal: e_importtotal,
e_exporttotal: e_exporttotal,
e_consumed: e_consumed,
bat_activecharge: bat_activecharge,
bat_activedischarge: bat_activedischarge,
e_total_string1: e_total_string1,
e_total_string2: e_total_string2,
e_total_string3: msg.symo12_string1,
e_total_string4: msg.symo12_string2,
e_total_opendtu: e_total_opendtu,
e_total_garage: msg.symo5_string1,
e_total: e_total,
e_total_gen24_ac: parseInt(global.get('Fronius_Live.E_Total_Gen24_AC')),
//bat_SOC_min: msg.payload.Body.Data["16318464"].channels.BAT_PERCENT_POWERRESTRICTION_SOC_MIN_F64 || 0,
bat_serial: battdata.attributes.serial || 0,
bat_sw_version: battdata.attributes.sw_version || 0,
bat_rawbyddata: JSON.parse(battdata.attributes.nameplate) || 0,
bat_SOC_min: JSON.parse(battdata.attributes.nameplate).min_soc || 5,
bat_capacity_wh: JSON.parse(battdata.attributes.nameplate).capacity_wh || 0,
bat_SOC: battdata.channels.BAT_VALUE_STATE_OF_CHARGE_RELATIVE_U16 || 0,
bat_SOH: battdata.channels.BAT_VALUE_STATE_OF_HEALTH_RELATIVE_U16 || 0,
bat_temp_cell: battdata.channels.BAT_TEMPERATURE_CELL_F64 || 0,
bat_temp_cell_max: battdata.channels.BAT_TEMPERATURE_CELL_MAX_F64 || 0,
bat_temp_cell_min: battdata.channels.BAT_TEMPERATURE_CELL_MIN_F64 || 0,
bat_livetimechg: battdata.channels.BAT_ENERGYACTIVE_LIFETIME_CHARGED_F64 || 0,
bat_livetimedischg: battdata.channels.BAT_ENERGYACTIVE_LIFETIME_DISCHARGED_F64 || 0,
bat_voltage: battdata.channels.BAT_VOLTAGE_DC_INTERNAL_F64 || 0,
bat_temp_ambiente: battdata.channels.DEVICE_TEMPERATURE_AMBIENTEMEAN_F32 || 0,
