How to get this data into influx db
I'm using a mqtt example with my Nano 33 IOT The data I am seeing is below. The arduino code is below. I can't figure out how to get the data into a influx database. Can someone give me a clue?
This is on a RP3, Bullesye, Node red v2.16.
Thanks,
Clutch
  "ACC_X": -0.475249052,
  "ACC_Y": 0.010773907,
  "ACC_Z": 9.909601212,
  "GYR_X": 1.220703125,
  "GYR_Y": -5.676269531,
  "GYR_Z": -2.44140625
#include <Arduino.h>
#include <SPI.h>
#include <Wire.h>
#include <Arduino_LSM6DS3.h>
#include <ArduinoJson.h>
#include <PubSubClient.h>
#include <WiFiNINA.h>
#define CONVERT_G_TO_MS2 9.80665f
#define FREQUENCY_HZ 104
#define INTERVAL_MS (1000000 / (FREQUENCY_HZ + 1))
struct Acc_senseData{
  float acc_x = 0.0F;
  float acc_y = 0.0F;
  float acc_z = 0.0F;
struct Gyr_senseData
  float gyr_x = 0.0F;
  float gyr_y = 0.0F;
  float gyr_z = 0.0F;
void setup_wifi();
void reconnect();
static char payload[256];
static Acc_senseData acc_data;
static Gyr_senseData gyr_data;
StaticJsonDocument<256> doc;
#define TOKEN  ""
#define DEVICEID ""
const char* ssid = "sorry";
const char* password = "uip5orh2tdmnv9vb";
const char mqtt_server[] = "192.168.1.124";
const char publishTopic[] = "v1/devices/me/telemetry";
WiFiClient wifiClient;
PubSubClient mqtt(wifiClient);
void setup_wifi(){
  delay(10);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while( WiFi.status() != WL_CONNECTED){
    delay(500);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect(){
  while(!mqtt.connected()){
    //Serial.print("Attempting MQTT connection ....");
    //String clientID = "nano33_accelerometer-";
    //clientID += String(random(0xffff), HEX);
    if (mqtt.connect(DEVICEID, TOKEN, NULL)) {
      Serial.println("Connected to MQTT Broker");
      digitalWrite(LED_BUILTIN, HIGH);
    else
      Serial.print("failed, rc=");
      Serial.print(mqtt.state());
      Serial.println("try again in 5 second");
      digitalWrite(LED_BUILTIN, LOW);
      delay(5000);
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(9600);
  while (!Serial);
  if (!IMU.begin())
    Serial.println("Failed to initialize IMU!");
    while(1);
  setup_wifi();
  mqtt.setServer(mqtt_server, 1883);
void loop() {
  if (!mqtt.connected())
    reconnect();
  mqtt.loop();
  static unsigned long last_interval_ms = 0;
  float a_x, a_y, a_z;
  float g_x, g_y, g_z;
  if (millis() > last_interval_ms + INTERVAL_MS)
    last_interval_ms = millis();
    IMU.readAcceleration(a_x, a_y, a_z);
    acc_data.acc_x = a_x;
    acc_data.acc_y = a_y;
    acc_data.acc_z = a_z;
    IMU.readGyroscope(g_x, g_y, g_z);
    gyr_data.gyr_x = g_x;
    gyr_data.gyr_y = g_y;
    gyr_data.gyr_z = g_z;
    doc["ACC_X"] = acc_data.acc_x * CONVERT_G_TO_MS2;
    doc["ACC_Y"] = acc_data.acc_y * CONVERT_G_TO_MS2;
    doc["ACC_Z"] = acc_data.acc_z * CONVERT_G_TO_MS2;
    doc["GYR_X"] = gyr_data.gyr_x;
    doc["GYR_Y"] = gyr_data.gyr_y;
    doc["GYR_Z"] = gyr_data.gyr_z;
    serializeJsonPretty(doc, payload);
    mqtt.publish(publishTopic, payload);
    Serial.println(payload);
Welcome to the forum @Clutch
Is that data a string or a javascript object (it will tell you if you feed it into a debug node). Show us a screenshot of the debug output.
