I am trying to get a sensor value or any value displayed on the "grove lcdrgb output" I get the following error in my terminal "LCD-RGB Invalid text: undefined
Sorry you need to provide more information, is this about node-red ?
If yes, what does your flow look like, debug node outputs etc.
I am not aware of a "grove lcdrgb" but looked it up.
Documentation describes:
GrovePi LcdRGB Output Node
Sends data to GrovePi LcdRGB I2C-Device.
The msg.payload should have separate keys. If rgb is not set, the information will be the once configured with the node itself.
text: <the lcd text>,
rgb: [255,0,0]
In the inject node you could set it to json:
{"text":"text on the lcd","rgb":[255,0,0]}
Thank you so much!!!!!!!!!!!!!!
Is it also possible to make this into a javascript function?
Sure, or use a change node.
I will try that and keep you posted.
Can you give me some pointers how to do that? I am a noob I am sorry.
There is great documentation available on this site.
I found this: How to use oled node
basically solved all my problems.
I am trying to get a sensor value on the "grove lcdrgb output"
GrovePi LcdRGB Output Node Sends data to GrovePi LcdRGB I2C-Device.
I have used a Inject node for text and RGB to set the color, this is working perfect
I have Temperature data in msg. payload.temperature:number
I would like to add the value example 18 to GrovePi LcdRGB I2C-Device.
How can I get this done?
Instead of setting the value of text to a constant string, set it to the value of msg.payload.temperature using a change node or function node.
As you have provided no flow or stated where msg.payload.temperature comes from and have not stated what prefix or suffix text you want to display I cannot help more that that except to say as you are new to node-red, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
As this thread is 2 years old and bmeester hasnt been online for over 1 year, it is unlikely he will respond - I am closing it.
If you still have issues, start a new thread.
