Hi everyone, I have issue that I want get data from txt file, but I not good Javascript, so I dont know how to get it,
Example I want get value " PH = 0 " Col1 and Col2 in 0: object
To concatenate strings to create " PH = 0 " you use the JavaScript + operator
e.g...
var string1 = "PH"; //TODO: get value from array element 0 col1
var string1 = "0"; //TODO: get value from array element 0 col2
msg.payload = string1 + " = " + string2;
To populate string1 and string2 variables with the ACTUAL VALUES, use the copy path button (as described below) and add msg. to the beginning. e.g. var string1 = msg.payload[0].col1;
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
