Hi, I'm trying to insert following date portion in to SQL db but it showing me this error."Conversion failed when converting date and/or time from character string." .
My msg: -
I've tried convert using parameter method.
USE [data]
INSERT INTO [dbo].[tags]
([id_tag]
,[name]
,[expiry]
,[group_m]
,[In_transaction]
,[blocked])
VALUES (@id,@name,@group_m,(convert(datetime,@dates,5)),@in_trans,@blocked);
show me how you have setup the MSSQL-PLUS node and parameters
Hi, Here is how I done that
ok, I suspect your date is not a date but a string.
Add a function node before the MSSQL node and enter...
node.warn(["typeof msg.date", typeof msg.date])
what do you see in the debug output?
try in that function before MSSQL
msg.date = new Date(msg.date)
to force it to a date type
Still same , I thought SQL convert query will do the trick
No, that requires the "string" be in a certain format (different to JS ISO format)
did you add the function before the MSSQL to change the date string to a data object?
did you remove the SQL convert and pass @dates directly in to the values(...)
Hi, I've checked this after the modification that you have suggested. The output is like this.
["typeof msg.date","object"]
Could you share a CREATE TABLE script and export a demo flow - I will take a look.
Here is the tabele. Note that Id column is going to modify to generate auto id with a seed
CREATE TABLE [dbo].[tags](
[id] [varchar](50) NOT NULL,
[id_tag] [varchar](50) NOT NULL,
[name] [varchar](50) NULL,
[expiry] [datetime] NULL,
[group_m] [varchar](50) NULL,
[In_transaction] [bit] NOT NULL,
[blocked] [bit] NOT NULL
) ON [PRIMARY]
GO
Set your MSSQL node parameter to datetime to match your schema and try again.
Also, looking closer at your query...
noob69:
USE [data]
([id_tag]
,[name]
,[expiry]
,[group_m]
,[In_transaction]
,[blocked])
If ID is an auto increment, DO NOT SEND a value for that field
ALSO - your fields are written in this order...
([id_tag] --1
,[name] --2
,[expiry] --3
,[group_m] --4
but you send
@id, --1
@name, --2
@group_m, --3
(convert(datetime,@dates,5)) --4
In other words, you are sending @group_m to the [expiry] field
My suspicion is ...
1. change your query to
USE [data]
( [id_tag]
,[name]
,[expiry]
,[group_m]
,[In_transaction]
,[blocked] )
VALUES ( @id,
@name,
@dates,
@group_m,
@in_trans,
@blocked );
2. change the @dates parameter to datetime type
... it will just work
(remember to delete [id_tag] and @id if id_tag is an auto increment field)
Yeah, Huge thanks for the noticing it. I was trying to update with datetime.now with a parameters. Then It alos failed. Thank You Very Much @Steve-Mcl .
