Yes, database table (which is shown also in the UI).
This is a part of a complex flow in progress. I tried to extract the part on which is focused the post.
[{"id":"e23226821db52820","type":"ui_dropdown","z":"d05f249a6f99c6bf","name":"","label":"Cerca Strumento","tooltip":"","place":"","group":"010506b862f616aa","order":3,"width":4,"height":1,"passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"options","topicType":"msg","className":"","x":370,"y":380,"wires":[["b4b550601c3abde5"]]},{"id":"ba20981416b74e3e","type":"ui_table","z":"d05f249a6f99c6bf","group":"2699aa19a99f500b","name":"Date Controllo","order":1,"width":20,"height":"9","columns":[{"field":"DATAULTIMOCONTROLLO","title":"Data Ultimo Controllo","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"DATASCADENZA","title":"Data Scadenza","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"RESPONSABILE","title":"Responsabile","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"STATON","title":"Stato","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"ID_Scad","title":"ID","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":1,"cts":true,"x":1160,"y":1060,"wires":[[]]},{"id":"c13df134ef23db78","type":"MSSQL","z":"d05f249a6f99c6bf","mssqlCN":"6fb70e68d89e36c4","name":"","outField":"payload","returnType":"0","throwErrors":"0","query":"SELECT CODIFICA FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]","modeOpt":"","modeOptType":"query","queryOpt":"","queryOptType":"editor","paramsOpt":"queryParams","paramsOptType":"msg","rows":"","rowsType":"msg","params":[{"output":true,"name":"CODIFICA","type":"VarChar","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}}],"x":240,"y":180,"wires":[["6e0a1c706a7d2fe4","380938770ffb58d4"]]},{"id":"6e0a1c706a7d2fe4","type":"debug","z":"d05f249a6f99c6bf","name":"Out DB","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":460,"y":200,"wires":[]},{"id":"4e062855148f77d2","type":"ui_form","z":"d05f249a6f99c6bf","name":"","label":"","group":"04fee1bcfe3710a2","order":2,"width":6,"height":1,"options":[{"label":"DATA ULTIMO CONTROLLO","value":"DATAULTIMOCONTROLLO","type":"date","required":true,"rows":null},{"label":"RESPONSABILE","value":"RESPONSABILE","type":"text","required":true,"rows":null},{"label":"NOTE","value":"NOTE","type":"text","required":false,"rows":null}],"formValue":{"DATAULTIMOCONTROLLO":"","RESPONSABILE":"","NOTE":""},"payload":"","submit":"INVIA","cancel":"CANCEL","topic":"topic2","topicType":"str","splitLayout":"","className":"","x":470,"y":860,"wires":[["3d853a67cbf1fdef","0113663611b555b1"]]},{"id":"ece9c901994b0e20","type":"debug","z":"d05f249a6f99c6bf","name":"Form Out","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":980,"wires":[]},{"id":"b4b550601c3abde5","type":"function","z":"d05f249a6f99c6bf","name":"","func":"pld = \"SELECT ID \" \npld = pld + \"FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]\"\npld = pld + \"WHERE CODIFICA = '\"+msg.payload+\"'\"\n\nmsg.payload = pld\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":320,"y":560,"wires":[["ccea13996967a098","57ec03dc7bac852f"]]},{"id":"ccea13996967a098","type":"MSSQL","z":"d05f249a6f99c6bf","mssqlCN":"6fb70e68d89e36c4","name":"","outField":"payload","returnType":"0","throwErrors":"0","query":"SELECT CODIFICA, MODELLO, FREQUENZATARATURA FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]\nWHERE CODIFICA = ","modeOpt":"","modeOptType":"query","queryOpt":"payload","queryOptType":"msg","paramsOpt":"queryParams","paramsOptType":"msg","rows":"","rowsType":"msg","params":[],"x":520,"y":560,"wires":[["cab67d7702b99345","8deadb13452e4b3d"]]},{"id":"57ec03dc7bac852f","type":"debug","z":"d05f249a6f99c6bf","name":"Out func 1","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":490,"y":520,"wires":[]},{"id":"4bf58cc4e60f5207","type":"join","z":"d05f249a6f99c6bf","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":810,"y":840,"wires":[["6372b652ebd01577","ed115efd4e13c62c"]]},{"id":"6372b652ebd01577","type":"debug","z":"d05f249a6f99c6bf","name":"join out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":940,"y":780,"wires":[]},{"id":"cab67d7702b99345","type":"change","z":"d05f249a6f99c6bf","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"topic1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":700,"wires":[["4bf58cc4e60f5207","ebbda513df9ccb02"]]},{"id":"b6f46ed1049f6a4e","type":"ui_text","z":"d05f249a6f99c6bf","group":"04fee1bcfe3710a2","order":1,"width":9,"height":1,"name":"","label":"Inserisci la data dell'ultimo controllo per lo strumento selezionato","format":"{{msg.payload}}","layout":"row-left","className":"","x":490,"y":800,"wires":[]},{"id":"8deadb13452e4b3d","type":"debug","z":"d05f249a6f99c6bf","name":"Out DB Cerca","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":580,"wires":[]},{"id":"60efcca2c61f0b9b","type":"inject","z":"d05f249a6f99c6bf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":240,"wires":[["c13df134ef23db78"]]},{"id":"38f6b27d6a758da3","type":"ui_button","z":"d05f249a6f99c6bf","name":"","group":"010506b862f616aa","order":1,"width":6,"height":1,"passthru":false,"label":"Refresh Data","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":130,"y":80,"wires":[["c13df134ef23db78","40a7f0e6592841e8"]]},{"id":"ebbda513df9ccb02","type":"debug","z":"d05f249a6f99c6bf","name":"topic","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":680,"wires":[]},{"id":"3d853a67cbf1fdef","type":"debug","z":"d05f249a6f99c6bf","name":"date out","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":880,"y":720,"wires":[]},{"id":"0113663611b555b1","type":"moment","z":"d05f249a6f99c6bf","name":"Day adjust","topic":"topic2","input":"payload.DATAULTIMOCONTROLLO","inputType":"msg","inTz":"Europe/Rome","adjAmount":"0","adjType":"days","adjDir":"add","format":"\"YYYY-MM-DD\"","locale":"en-US","output":"payload.DATAULTIMOCONTROLLO","outputType":"msg","outTz":"Europe/Rome","x":650,"y":880,"wires":[["4bf58cc4e60f5207","ece9c901994b0e20"]]},{"id":"40a7f0e6592841e8","type":"debug","z":"d05f249a6f99c6bf","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":250,"y":20,"wires":[]},{"id":"ed115efd4e13c62c","type":"MSSQL","z":"d05f249a6f99c6bf","mssqlCN":"6fb70e68d89e36c4","name":"","outField":"payload","returnType":"0","throwErrors":"0","query":"UPDATE [DB_Strumentazione].[dbo].[SCADENZIARIO]\nSET STATO =(@STATO)\nWHERE ID_STRUM=(@ID_STRUM) and ID=(SELECT MAX(ID) FROM [DB_Strumentazione].[dbo].[SCADENZIARIO])\n\nINSERT INTO [DB_Strumentazione].[dbo].[SCADENZIARIO]\n(ID_STRUM,DATAULTIMOCONTROLLO,RESPONSABILE,NOTE) \nVALUES (@ID_STRUM, @DATAULTIMOCONTROLLO,@RESPONSABILE,@NOTE)\n\n\nSELECT [dbo].[SCADENZIARIO].ID as ID_Scad,\n[dbo].[SCADENZIARIO].ID_STRUM,\nFORMAT( DATAULTIMOCONTROLLO, 'yyyy-MM-dd') as DATAULTIMOCONTROLLO,\n[dbo].[SCADENZIARIO].RESPONSABILE,\n[dbo].[SCADENZIARIO].STATO, \n[dbo].[StrumentazioneAttrezzature].ID,\n[dbo].[StrumentazioneAttrezzature].FREQUENZATARATURA, \n[dbo].[StrumentazioneAttrezzature].CODIFICA,\nFORMAT(dateadd(day,cast(FREQUENZATARATURA as int)-1, DATAULTIMOCONTROLLO),'yyyy-MM-dd') as DATASCADENZA,\n(case when [dbo].[SCADENZIARIO].STATO=1 then 'Done'\n when [dbo].[SCADENZIARIO].STATO is null then 'None'\n end) as STATON\n \nFROM [dbo].[SCADENZIARIO]\nINNER JOIN [dbo].[StrumentazioneAttrezzature]\nON [dbo].[SCADENZIARIO].ID_STRUM = [dbo].[StrumentazioneAttrezzature].ID\nWHERE [dbo].[StrumentazioneAttrezzature].ID = (@ID)","modeOpt":"","modeOptType":"query","queryOpt":"","queryOptType":"editor","paramsOpt":"","paramsOptType":"editor","rows":"","rowsType":"msg","params":[{"output":false,"name":"STATO","type":"int","valueType":"num","value":"1","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}},{"output":false,"name":"ID_STRUM","type":"int","valueType":"msg","value":"payload.topic1[0].ID","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}},{"output":false,"name":"DATAULTIMOCONTROLLO","type":"Date","valueType":"msg","value":"payload.topic2.DATAULTIMOCONTROLLO","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}},{"output":false,"name":"RESPONSABILE","type":"VarChar","valueType":"msg","value":"payload.topic2.RESPONSABILE","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}},{"output":false,"name":"NOTE","type":"VarChar","valueType":"msg","value":"payload.topic2.NOTE","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}},{"output":false,"name":"ID","type":"int","valueType":"msg","value":"payload.topic1[0].ID","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}}],"x":900,"y":1040,"wires":[["ba20981416b74e3e"]]},{"id":"380938770ffb58d4","type":"change","z":"d05f249a6f99c6bf","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"$.payload.CODIFICA","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":260,"wires":[["e23226821db52820"]]},{"id":"010506b862f616aa","type":"ui_group","name":"Ricerca Strumento","tab":"084d9d4d7c0a6ac5","order":3,"disp":false,"width":"20","collapse":false,"className":""},{"id":"2699aa19a99f500b","type":"ui_group","name":"Storico Date Controllo","tab":"084d9d4d7c0a6ac5","order":6,"disp":true,"width":"20","collapse":false,"className":""},{"id":"6fb70e68d89e36c4","type":"MSSQL-CN","name":"DB_Strumentazione","server":"","port":"","encyption":true,"trustServerCertificate":true,"database":"DB_Strumentazione","useUTC":false,"connectTimeout":"30000","requestTimeout":"","cancelTimeout":"","pool":"","parseJSON":false,"enableArithAbort":true},{"id":"04fee1bcfe3710a2","type":"ui_group","name":"Inserimento data controllo","tab":"084d9d4d7c0a6ac5","order":7,"disp":true,"width":"10","collapse":false,"className":""},{"id":"084d9d4d7c0a6ac5","type":"ui_tab","name":"Inserimento Date Controllo","icon":"assignment","order":5,"disabled":false,"hidden":false}]
