How to merge multi csv file in one with deferent time
i wanna to merge csv fils to be like this
jour | heure | capteur | conductivity | temp | capteur2 | level | capteur3| pression02
30/1/23 | 11:25:05 | 106 | 325 | 25 .1 | 108 | 85 | 101 | 4.5
30/1/23 | 11:25:18 | 106 | 360 | 25.6 | 108 | 89 | 101 | 4.8
30/1/23 | 11:25:18 | - | - | - | 108 | 89 | 101 | 4.8
30/1/23 | 11:25:30| 106 | 425 | 25.7 | 108 | 81 | 101 | 4.3
        "id": "f6ed1294e1ce6e01",
        "type": "inject",
        "z": "1662802a7cd6b055",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 410,
        "y": 420,
                "fda448b8af022711"
        "id": "d0e268426bdf303e",
        "type": "function",
        "name": "PORT 01 flow SM8100",
        "func": "msg.payload = {\n  \"code\": \"request\",\n  \"cid\": 101,\n  \"adr\": \"/iolinkmaster/port[1]/iolinkdevice/pdin/getdata\"\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 660,
        "y": 560,
                "ce9d246ba38e5bb0"
        "id": "14c399a0f09c4d0b",
        "type": "function",
        "name": "PORT 2 NIVEAU LMT121",
        "func": "msg.payload = {\n  \"code\": \"request\",\n  \"cid\": 102,\n  \"adr\": \"/iolinkmaster/port[2]/iolinkdevice/pdin/getdata\"\n}\nmsg.topic = msg.payload\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 500,
                "99f560e177247730"
        "id": "fda448b8af022711",
        "type": "function",
        "name": "PORT 6 conductivity LDL100",
        "func": "msg.payload = {\n  \"code\": \"request\",\n  \"cid\": 106,\n  \"adr\": \"/iolinkmaster/port[6]/iolinkdevice/pdin/getdata\"\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 680,
        "y": 420,
                "b4a63afb7309ede7"
        "id": "b4a63afb7309ede7",
        "type": "www-request",
        "method": "POST",
        "ret": "obj",
        "url": "169.254.139.233",
        "follow-redirects": true,
        "persistent-http": true,
        "tls": "",
        "x": 950,
        "y": 420,
                "b00fd724ee163b93",
                "c5a34b3b975f4022",
                "1759ed2b1f84ac3b"
        "id": "b00fd724ee163b93",
        "type": "debug",
        "name": "request info",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 970,
        "y": 380,
        "id": "52845433fe1fab9c",
        "type": "function",
        "name": "function7",
        "func": "var flowData = 0;\n\n// Extract the hexadecimal string value from the msg.payload\nvar hexValue = msg.payload;\n\n// Convert the hexadecimal string to a decimal integer\nvar decimalValue = parseInt(hexValue, 16);\n\n// Convert the decimal value to flow rate in cubic meters per hour\nvar flowRate = decimalValue * 0.001;\n\n// Convert the flow rate from cubic meters per hour to liters per minute\nflowData = flowRate * 1000 / 60;\n\n// Assign the converted flow rate data to the msg.payload\nmsg.payload = flowData;\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1200,
        "y": 560,
                "b80c33255e8b473c",
                "847e3f1027d9472b"
        "id": "b80c33255e8b473c",
        "type": "debug",
        "name": "FLOW",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 1430,
        "y": 560,
        "id": "ce9d246ba38e5bb0",
        "method": "POST",
        "ret": "obj",
        "tls": "",
        "x": 970,
        "y": 560,
                "52845433fe1fab9c",
                "b00fd724ee163b93"
        "id": "8ef4792bdf327979",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "15",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 410,
        "y": 560,
        "id": "99f560e177247730",
        "method": "POST",
        "ret": "obj",
        "tls": "",
        "x": 970,
        "y": 500,
                "c3a6373937c12c2a"
        "id": "c5a34b3b975f4022",
        "type": "function",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar flowmeter = parseInt(part1, 16);\nvar Temp = parseInt(part2, 16) / 10;\nvar now = new Date();\n\n// now.setTime(now.getTime() - 1000*60*60*24*i);\nlet yyyy = now.getFullYear();\nlet mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nlet dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nlet hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nlet mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nlet ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\nlet time_jour = yyyy + \"/\" + mm + \"/\" + dd\nlet time_heure = hh + \":\" + mmm + \":\" + ss\nmsg.payload = { \"jour\": time_jour, \"heure\": time_heure, \"capteur\": msg.payload.cid, \"flow\": flowmeter, \"Temperature_C\": Temp };\nmsg.topic = {};\nmsg.topic.flow = flowmeter;\nmsg.topic.temp = Temp;\nreturn msg;\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1180,
        "y": 420,
                "aa98994857bc51d1",
                "2751f202d7904aec"
        "id": "aa98994857bc51d1",
        "type": "debug",
        "name": "conductivity",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1390,
        "y": 420,
        "id": "c3a6373937c12c2a",
        "type": "function",
        "name": "level 1",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar level=parseInt(part1,16);\nvar now = new Date();\n\n\n   // now.setTime(now.getTime() - 1000*60*60*24*i);\n    let yyyy = now.getFullYear();\n    let mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n    let dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n    let hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n    let mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n    let ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\nvar time_jour = yyyy+\"/\"+mm+\"/\"+dd\nlet time_heure = hh+\":\"+mmm+\":\"+ss\n\nmsg.payload = {\"jour\":time_jour,\"heure\":time_heure,\"capteur\":msg.payload.cid,\"Level\":level};\nmsg.topic = \"Level etat 1\"\n//let output = [];\n//let newfile = {\"filename\":\"\",\"pattern\":\"\"};\n    // Generate out file name pattern\n//CC = \"AWS_D05E40\"+ yyyy + mm + dd + \".csv\";\n    // Full filename with path \n//fname = \"E:\\DATAS\\AWS_D05E40\\\"+CC;\n// Shell script only needs the filename without the path\n//  newfile.payload = newfile.fname;\n //output.push(fname);\n// return output;\n return msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1190,
        "y": 500,
                "b76c9e651bc2d543",
                "c499f8441654e8b7"
        "id": "dd34f162cebc4c8f",
        "type": "function",
        "name": "PORT 5 NIVEAU LMT121",
        "func": "msg.payload = {\n  \"code\": \"request\",\n  \"cid\": 105,\n  \"adr\": \"/iolinkmaster/port[5]/iolinkdevice/pdin/getdata\"\n}\nmsg.topic = msg.payload\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 460,
                "bd6a6bcbeff45418"
        "id": "bd6a6bcbeff45418",
        "method": "POST",
        "ret": "obj",
        "tls": "",
        "x": 970,
        "y": 460,
                "168153b4657897c6",
                "df7a3689e248ea34"
        "id": "8c6c271c8049e13b",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "3",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 410,
        "y": 460,
                "dd34f162cebc4c8f"
        "id": "168153b4657897c6",
        "type": "function",
        "name": "level 0",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar level=parseInt(part1,16)/16;\nvar now = new Date();\nlet yyyy = now.getFullYear();\nlet mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nlet dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nlet hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nlet mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nlet ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\nlet time_jour = yyyy + \"/\" + mm + \"/\" + dd\nlet time_heure = hh + \":\" + mmm + \":\" + ss\nmsg.payload = {\n    \"jour\": time_jour, \"heure\": time_heure,\"capteur3\":msg.payload.cid,\"Level\":level};\nmsg.topic = \"Level etat 0\"\n//let newfile = {\"filename\":\"\",\"pattern\":\"\"};\n    // Generate out file name pattern\n//CC = \"AWS_D05E40\"+ yyyy + mm + dd + \".csv\";\n    // Full filename with path \n//fname = \"E:\\DATAS\\AWS_D05E40\\\"+CC;\n// Shell script only needs the filename without the path\n//  newfile.payload = newfile.fname;\n //output.push(fname);\n// return output;\n return msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1190,
        "y": 460,
                "c499f8441654e8b7",
                "b76c9e651bc2d543",
                "554c40d06cd22395"
        "id": "c499f8441654e8b7",
        "type": "debug",
        "name": "LEVEL",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1400,
        "y": 480,
        "id": "f8507bac38ae9404",
        "type": "function",
        "name": "PT-3-PORT 5 PRESSION PV7023",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 660,
                "1f3e96d1408f14b8"
        "id": "1f3e96d1408f14b8",
        "method": "POST",
        "ret": "obj",
        "tls": "",
        "x": 970,
        "y": 660,
                "ee12e352c022f805"
        "id": "b8c0e08c0144cc81",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "16",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 410,
        "y": 660,
                "f8507bac38ae9404"
        "id": "ee12e352c022f805",
        "type": "function",
        "name": "pression02",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar pression02=parseInt(part1,16);\nvar now = new Date();\n\n\n   // now.setTime(now.getTime() - 1000*60*60*24*i);\n    let yyyy = now.getFullYear();\n    let mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\n    let dd  = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\n    let hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\n    let mmm  = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\n    let ss  = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\nvar time_jour = yyyy+\"/\"+mm+\"/\"+dd\nlet time_heure = hh+\":\"+mmm+\":\"+ss\n\nmsg.payload = { \"jour\": time_jour, \"heure\": time_heure,\"capteur\":msg.payload.cid,\"pression\":pression02};\nmsg.topic = \"pression\", pression02\n//let output = [];\n//let newfile = {\"filename\":\"\",\"pattern\":\"\"};\n    // Generate out file name pattern\n//CC = \"AWS_D05E40\"+ yyyy + mm + dd + \".csv\";\n    // Full filename with path \n//fname = \"E:\\DATAS\\AWS_D05E40\\\"+CC;\n// Shell script only needs the filename without the path\n//  newfile.payload = newfile.fname;\n //output.push(fname);\n// return output;\n return msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1170,
        "y": 660,
                "5b835f9f442d7544",
                "e4fd5b1e72835f69",
                "1c781ed18b22bb78"
        "id": "5b835f9f442d7544",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1410,
        "y": 700,
        "id": "e4fd5b1e72835f69",
        "type": "ui_gauge",
        "group": "9acac3b2428700ea",
        "order": 2,
        "width": 6,
        "height": 5,
        "gtype": "gage",
        "title": "PT-03-PRESSUR ",
        "label": "BAR",
        "format": "{{value}}",
        "min": 0,
        "max": "40",
        "colors": [
            "#e6e600",
            "#00b500",
            "#e6b400"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 1410,
        "y": 660,
        "id": "847e3f1027d9472b",
        "type": "csv",
        "name": "Data en csv",
        "sep": ";",
        "hdrin": true,
        "hdrout": "none",
        "multi": "one",
        "ret": "\\r\\n",
        "temp": "jour,heure, capteur, flow, Temperature_C",
        "skip": "0",
        "strings": true,
        "include_empty_strings": "",
        "include_null_values": "",
        "x": 1230,
        "y": 280,
                "5421a5a254e2968d"
        "id": "71a75d335c19731f",
        "type": "debug",
        "name": "read saved",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1670,
        "y": 280,
        "id": "5421a5a254e2968d",
        "type": "file",
        "name": "SM8100",
        "filename": "C:\\Users\\issam\\Desktop\\Nouveau dossier\\node-red\\FLOW.csv",
        "filenameType": "str",
        "appendNewline": false,
        "createDir": true,
        "overwriteFile": "false",
        "encoding": "none",
        "x": 1420,
        "y": 280,
                "71a75d335c19731f"
        "id": "3cd989f73e400353",
        "type": "ui_text",
        "order": 21,
        "width": 0,
        "height": 0,
        "label": "LEVEL =",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "className": "",
        "x": 1680,
        "y": 460,
        "id": "b76c9e651bc2d543",
        "type": "change",
        "rules": [
                "t": "change",
                "p": "topic",
                "pt": "msg",
                "from": "Level etat 0",
                "fromt": "str",
                "to": "LOW",
                "tot": "str"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "Level etat 1",
                "fromt": "str",
                "to": "HIGH",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1660,
        "y": 500,
                "3cd989f73e400353"
        "id": "c5567f1cde1066bd",
        "type": "ui_gauge",
        "order": 3,
        "width": "6",
        "height": 5,
        "gtype": "gage",
        "title": "Feed Conductivity",
        "label": "units",
        "min": 0,
        "max": "3000",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "1400",
        "seg2": "2500",
        "className": "",
        "x": 1430,
        "y": 380,
        "id": "2751f202d7904aec",
        "type": "csv",
        "sep": ";",
        "hdrin": true,
        "hdrout": "none",
        "multi": "one",
        "ret": "\\r\\n",
        "temp": "jour,heure, capteur, conductivity, Temperature_C",
        "skip": "0",
        "strings": true,
        "x": 1230,
        "y": 340,
                "cbdc9370910f8409"
        "id": "cbdc9370910f8409",
        "type": "file",
        "name": "Conductivity & Temp",
        "filename": "C:\\Users\\issam\\Desktop\\Nouveau dossier\\node-red\\Conductivity&temp.csv",
        "createDir": true,
        "encoding": "none",
        "x": 1440,
        "y": 340,
                "71a75d335c19731f"
        "id": "1c781ed18b22bb78",
        "type": "csv",
        "sep": ";",
        "hdrin": true,
        "hdrout": "none",
        "multi": "one",
        "ret": "\\r\\n",
        "temp": "jour,heure, capteur, pression02",
        "skip": "0",
        "strings": true,
        "x": 1330,
        "y": 620,
                "1f65afe01b79249a"
        "id": "1f65afe01b79249a",
        "type": "file",
        "name": "pression 01 data",
        "filename": "C:\\Users\\issam\\Desktop\\Nouveau dossier\\node-red\\D1.csv",
        "createDir": true,
        "encoding": "none",
        "x": 1510,
        "y": 620,
                "71a75d335c19731f"
        "id": "554c40d06cd22395",
        "type": "csv",
        "sep": ";",
        "hdrin": true,
        "hdrout": "none",
        "multi": "one",
        "ret": "\\r\\n",
        "temp": "jour,heure,capteur3, level",
        "skip": "0",
        "strings": true,
        "x": 1250,
        "y": 220,
                "8e79c3eecd6eeae8"
        "id": "8e79c3eecd6eeae8",
        "type": "file",
        "name": "LEVEL",
        "filename": "C:\\Users\\issam\\Desktop\\Nouveau dossier\\node-red\\LEVEL.csv",
        "createDir": true,
        "encoding": "none",
        "x": 1400,
        "y": 220,
                "71a75d335c19731f"
        "id": "1759ed2b1f84ac3b",
        "type": "function",
        "name": "function 60",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar conductivity = parseInt(part1, 16);\nvar Temp = parseInt(part2, 16) / 10;\nvar now = new Date();\n\n// now.setTime(now.getTime() - 1000*60*60*24*i);\nlet yyyy = now.getFullYear();\nlet mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nlet dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nlet hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nlet mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nlet ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\nlet time_jour = yyyy + \"/\" + mm + \"/\" + dd\nlet time_heure = hh + \":\" + mmm + \":\" + ss\nmsg.payload = conductivity \n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1325,
        "y": 380,
                "c5567f1cde1066bd"
        "l": false
        "id": "96b1ba3e4681371f",
        "type": "ui_gauge",
        "order": 3,
        "width": "6",
        "height": 5,
        "gtype": "gage",
        "title": "Level tank",
        "label": "L/min",
        "min": 0,
        "max": "3000",
        "colors": [
            "#fff700",
            "#00b400",
            "#ffbb00"
        "seg1": "1400",
        "seg2": "2500",
        "className": "",
        "x": 1410,
        "y": 460,
        "id": "df7a3689e248ea34",
        "type": "function",
        "name": "function 62",
        "func": "var str = msg.payload.data.value;\nvar part1 = str.substr(0, 8);\nvar part2 = str.substr(16, 4);\nvar level = parseInt(part1, 16);\nvar now = new Date();\n\n// now.setTime(now.getTime() - 1000*60*60*24*i);\nlet yyyy = now.getFullYear();\nlet mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nlet dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nlet hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nlet mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nlet ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\nlet time_jour = yyyy + \"/\" + mm + \"/\" + dd\nlet time_heure = hh + \":\" + mmm + \":\" + ss\nmsg.payload = level\n\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1315,
        "y": 460,
                "96b1ba3e4681371f"
        "l": false
        "id": "16b96523c9e6600c",
        "type": "comment",
        "name": "set were u want to put your file \"csv\"",
        "info": "",
        "x": 1520,
        "y": 180,
        "id": "1a5c178c30251b26",
        "type": "comment",
        "name": "please  check port if it is the correct one !",
        "info": "",
        "x": 690,
        "y": 380,
        "id": "9acac3b2428700ea",
        "type": "ui_group",
        "name": "sys osis",
        "tab": "6dcd6da7b80584f0",
        "order": 5,
        "disp": true,
        "width": "26",
        "collapse": false,
        "className": ""
        "id": "6dcd6da7b80584f0",
        "type": "ui_tab",
        "name": "sys osis v3",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
