how to open image image from local file directory?
please help me
i want to open an image in the dashboard from local file in the raspberry pi?
please help me
Loading an image (or any file for that matter) from the machine where node-red is running is as simple as using and file in node.
I'm gonna hazard a guess that you want to do more than just load it. Perhaps edit it? Display it in a dashboard?
There are plenty of examples if you search.
Hi - Look in your settings.js file for this httpStatic section, something like this:
// When httpAdminRoot is used to move the UI to a different root path, the
// following property can be used to identify a directory of static content
// that should be served at http://localhost:1880/.
httpStatic: '/home/pi/public',
As it suggests, you can then serve all the PI's local files from under that directory.
Just make sure to follow the instructions on that first line (set a different root path),
since the default url '/' will overlap with the urls to your local files.
Is this what you are looking to do?
If you want to load and process an image, you could use noee-red-contrib-image-tools
As it load an image from file location and can convert an image to base64 you can inject that into a UI template node for displaying it in the dashboard.
want to display the image captured from raspberry pi camera. i have got
the camerapi node but it stores in /home/pi/pictures directory i want to display every image captured during a button touch.
hy gosaye_1, are you finish your problem about display captured from local file?
Hi @budiman098 you'd be better off creating a new topic and describe your exact requirements and what you have tried so far.
Helpful info should include...
