Hi from Germany.
I use the old 433mhz transmitter and SonOff-433 to send commands to shelly devices.
How to actually i can only send open or close without using the stop command.
I suppress each message by 1 sec because I have 3 receivers on 3 floors.
Than I check the sequence string and send finally open or close command to the shelly roller units.
Con someone tell me what to add to have the function open-stop-open or close-stop-close. So if i press any button (open or close) after pressing any button before to stop the roller.
"id": "bc2edfa1.b6ad1",
"type": "switch",
"z": "f1fe3f5b.1fe31",
"g": "c03beb6139b8f0c9",
"name": "WZ Tür",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "cont",
"v": "Data\":\"550015\",\"RfKey\":\"None\"",
"vt": "str"
"t": "cont",
"v": "Data\":\"550014\",\"RfKey\":\"None\"",
"vt": "str"
"checkall": "true",
"repair": true,
"outputs": 2,
"x": 640,
"y": 780,
"f1d7ec6d.ce3bd"
"8a2fcf90.23853"
"id": "f1d7ec6d.ce3bd",
"type": "http request",
"name": "Open",
"method": "POST",
"ret": "txt",
"paytoqs": "ignore",
"url": "http://192.168.15.143/roller/0?go=open",
"tls": "",
"persist": false,
"proxy": "",
"insecureHTTPParser": false,
"authType": "",
"senderr": false,
"headers": [],
"x": 950,
"y": 680,
"id": "8a2fcf90.23853",
"name": "Close",
"method": "POST",
"ret": "txt",
"url": "http://192.168.15.143/roller/0?go=close",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 950,
"y": 800,
