Hello friends! I'm currently doing a project sending data from Watson IBM IoT to Cloudant through Node-Red, however, the data arrives in the database all separately, like in the photo.
I would like to know how I can organize them into one. Can you help me?
You need to put a Debug node before and after the function node - see what is going into your function then you should understand.
is there the debug before the function:
And after:
Can you help me please @Steve-Mcl ?
As you can see the values come through separately.
I would suggest the following...
After the IBM iot node, put a switch node to test msg.topic is == to one of the 7 topics you are interested in. Then feed all 7 outputs of the switch node to a join node set for manual mode, key/value mode, 7 parts, subsequent values.
Once you have that working you should see all values in one message & you can used the "copy path" method I showed you before - to build 1 object.
See this article in the cookbook for an example of how to join messages into one object.
Apparently it worked, but how do I get the values ​​from this place in the function? I tried here and it's not going the way I tried... Can you help me with this last step?
@Steve-Mcl
Use "copy path" button on the property in the debug message.
then paste it into your function code (pre-pend with msg.)
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
There are tonnes of tip and tricks - I always recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Really thanks
@Steve-Mcl ! Thanks for helping me like this through links, instead of copying, I learned. Thank you very much
