How to pull a variable from an array in payload
Hi all
Hoping someone can help me. I am trying to pull sensor information from a device (MQTT), but having trouble extracting just what I need from the payload.
Debug output looks like this:
7/13/2022, 10:24:01 AM
node: 0c1ee5723f948408meraki/v1/mt/L_585467951558182753/ble/{DeviceMAC}/temperature : msg : Object
object >
topic: "meraki/v1/mt/L_585467951558182753/ble/{DeviceMAC}/temperature"
payload: "{"ts":"2022-07-13T08:16:37Z","fahrenheit":75.5,"celsius":24.2}"
qos: 0
retain: true
_msgid: "f62fd05586202cef"
When I go to extract "fahrenheit":75.5, I try to do it like this:
msg.payload[1] but that only seems to get me """, msg.payload[2] is "t", msg.payload[3] is "s", so it seems that the payload is not an actual array, it seems to be reading it as a string?. Does that make sense?
Any ideas how I can extract any of those 3 values? (timestamp, F, C)
In this case msg.payload is an object (objects are surrounded by curly braces {}), not an array (arrays are surrounded by brackets []). You can access them like msg.payload.ts or msg.payload.fahrenheit rather than msg.payload[X]
msg.payload could also be a JSON string, in which case you would need to convert it into an object first.
Use the built in tools provided...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Thank you for your reply. Sorry, forgot to mention that I had tried that but I get undefined in the debug output
Yeah I think I do need to convert it to an object first, let me figure that out and see what I get
It looks like payload is a string.
Are you outputting an object from the mqtt node? If not select output a parse object in the mqtt node config.
Then fahrenheit will be an object property, You will then access it at msg.payload.fahrenheit
Great callout! Didnt even think to look at what my mqtt node was configured as, it was set to automatic (string or buffer)
I changed it to JSON object, and now I can call on it using msg.payload.fahrenheit
Thank you all for your help and guidance! As you can tell, I am a newbie, but love learning new things :slight_smile:
