I have a flow, so that when power consumption is < 5 it should send 1x email.
Now, when value is < 5, I recive many, many, mails.
How can I change the flow to only recive 1 mail?
Thanks and regards
gwaag
maybe use the Filter / RBE node to remove duplicates and only send when they change.
Try this demo to understand how to convert the number to a boolean then you can watch for change from true->false->true and filter (RBE) to ignore same message being sent....
demo flow (use CTRL-I to import into node-red)
[{"id":"929dad11814b3aa5","type":"inject","z":"c876e57260edd2ab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"3","payloadType":"num","x":1010,"y":600,"wires":[["909af9087aebd993"]]},{"id":"28af9ec052c6ca4d","type":"inject","z":"c876e57260edd2ab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":1010,"y":640,"wires":[["909af9087aebd993"]]},{"id":"3989f467f38f0045","type":"inject","z":"c876e57260edd2ab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"-2","payloadType":"num","x":1010,"y":680,"wires":[["909af9087aebd993"]]},{"id":"0113fde212b1ef73","type":"inject","z":"c876e57260edd2ab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"-7","payloadType":"num","x":1010,"y":720,"wires":[["909af9087aebd993"]]},{"id":"bc209cd296d4f26c","type":"inject","z":"c876e57260edd2ab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"-10","payloadType":"num","x":1010,"y":760,"wires":[["909af9087aebd993"]]},{"id":"909af9087aebd993","type":"switch","z":"c876e57260edd2ab","name":"<= -5? \\n > -5","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"-5","vt":"num"},{"t":"gt","v":"-5","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1230,"y":680,"wires":[["86df9b3115940317"],["a019054f57ede562"]]},{"id":"86df9b3115940317","type":"change","z":"c876e57260edd2ab","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"cold","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":660,"wires":[["7a034e5fd04e10be"]]},{"id":"a019054f57ede562","type":"change","z":"c876e57260edd2ab","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"cold","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":700,"wires":[["7a034e5fd04e10be"]]},{"id":"7a034e5fd04e10be","type":"rbe","z":"c876e57260edd2ab","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":1620,"y":680,"wires":[["a98e3ede03c3585e"]]},{"id":"a98e3ede03c3585e","type":"switch","z":"c876e57260edd2ab","name":"is cold?","property":"payload","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":1380,"y":780,"wires":[["6e250c7f3f5d5599"]]},{"id":"6e250c7f3f5d5599","type":"debug","z":"c876e57260edd2ab","name":"Send an email","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1550,"y":780,"wires":[]}]
