I am currently using global variables to display data from different function. The data does not display real time changes. if I stop the flow, the value of the output changes. How can I make it so the values being displayed are updated real-time?
global variables are not reactive (by design)
there is a hack I posted (some time ago) to make them reactive but this no longer really flow programming (you lose sight of what is changing and all the wonderful things node-red is about)
Instead, if you share a minimal flow example with some background of what you are doing & why - we can probably show you an event driven alternative way of achieving your goal.
Thank you, it works now!
