How to reset rbe?
I try to reset narrowband but maybe I don't understand how this works.
10 = PASS
10 = PASS
10 = PASS
12 = BLOCK because change of value compared to last output is greater or equal to 1
inject "reset" = to clear the stored value for all topics
12 = should pass now....but it doesn't.....
000
How can I reset narrowband ?
[{"id":"57867a06.406d7c","type":"rbe","z":"886a888e.44f678","name":"","func":"narrowbandEq","gap":"1","start":"","inout":"out","property":"payload","x":730,"y":3340,"wires":[["ff2bae21.524fd8"]]},{"id":"dafdac50.01106","type":"inject","z":"886a888e.44f678","name":"","topic":"","payload":"12","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":530,"y":3300,"wires":[["57867a06.406d7c"]]},{"id":"8175f9fe.c3f1f8","type":"inject","z":"886a888e.44f678","name":"","topic":"","payload":"10","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":530,"y":3340,"wires":[["57867a06.406d7c"]]},{"id":"80d56384.e7ab6","type":"inject","z":"886a888e.44f678","name":"","topic":"","payload":"reset","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":530,"y":3380,"wires":[["57867a06.406d7c"]]},{"id":"ff2bae21.524fd8","type":"debug","z":"886a888e.44f678","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":3340,"wires":[]}]
You have set msg.payload to the string "reset" whereas you need to set msg.reset. It isn't clear from the help what you have to set it to, but I think setting it to boolean true would probably do it.
reset
Even a blank msg causes a reset.
Thank's !!! Now it works....
You don't need to use a change node, just format your inject node the same as my screenshot above.
@GeorgeX may not be using an up to date version of node red, so may not be able to set msg.reset in the inject node.
