I have a python script that uses some libraries that works only on windows ! I tried invoking this script from node red but it isn't recognized ! If anyone Has solved this problem before , i would be grateful ! thank you in advance .
Welcome to the forum.
Is Node Red running on the same machine as the script?
Thank you And Sorry for Late Answer , yes
running on the same machine .
Make sure you specify the full path to the script and to the Python command.
Hi @joualm - welcome to the forum
How are you doing this? Exec node? a contrib node? Something else?
What exactly happens (show logs / debug etc)
