How to send sensor data to firebase real time database?
The link of the RTDB is .firebasedatabase.app/.
The Node-red node I found for the Firebase is firebaseio.com.
How to solve it?
Have you tried any of the Firebase nodes available ?
https://flows.nodered.org/search?term=Firebase
I am in the same boat. I am trying to send sensor data to firebase.
The node you're referring to is old and deprecated, however a quick work around is to base your project in the USA. Mind you, you cannot use JSON webtoken so security is pretty loose.
Hit me up, if you'd like to collaborate as several brains on a similar problems are always better than one.
