ok, but why do you have it set to send strings - set this to binary / buffer
Also...
can you attach a debug node to the output of function 4 so we can see what is being sent into the serial node?
Yes of course, the output of the function is: [ 170, 63, 0, 17 ]
And when pressing on the output, it opens and shows this:
buffer[4]
0: 0xaa
1: 0x3f
2: 0x0
3: 0x11
Which in both cases are not right and should not be like this!
which then leads to the question 'what is inside "function 4"'
See my previous post...
Can you please suggest a way to write the function? Before I start looking onto the buffer maker. Since I do not know what endianness is..
Just an observation, Steve asked 3 or 4 times what the content of function 4 is...
Oh I thought I answered what's the content of function 4. It's just this code:
var Arr1 = Buffer.from([0xaa,0x3f,0x00,0x00,0xf0,0x11]);
msg.payload = Arr1;
Your function code 2- works , as I've just done the same experiment.
var buf = Buffer.from([0xaa, 0x3f, 0x00, 0x00, 0xf0, 0x11]);
msg.payload = buf;
Code of my flow
"id": "4a65bd5989e6e48a",
"type": "tab",
"label": "流程 1",
"disabled": false,
"info": "",
"env": []
"id": "deb4b3071092f4b4",
"type": "serial-port",
"serialport": "/dev/ttyS4",
"serialbaud": "9600",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"dtr": "none",
"rts": "none",
"cts": "none",
"dsr": "none",
"newline": "1",
"bin": "false",
"out": "time",
"addchar": "",
"responsetimeout": "10000"
"id": "d4aee0b6830813cf",
"type": "serial out",
"z": "4a65bd5989e6e48a",
"serial": "deb4b3071092f4b4",
"x": 400,
"y": 320,
"id": "f0a90340ad0b821f",
"type": "debug",
"name": "debug 1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 440,
"y": 220,
"id": "daab7c3dfd21638b",
"type": "function",
"name": "function 1",
"func": "var buf = Buffer.from([0xaa, 0x3f, 0x00, 0x00, 0xf0, 0x11]);\nmsg.payload = buf;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 220,
"y": 280,
"f0a90340ad0b821f",
"d4aee0b6830813cf"
"id": "782bddc5e8783cf7",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 150,
"y": 200,
"daab7c3dfd21638b"
Thank you for your time, I tried the exact function and I attached a debugger to the "serial in" node, it is giving this error: "TypeError: The List[1]" argument must be an instance of Buffer or Unit8Array. Received type is string (' ')"
And the node will keep in the waiting mode.
Can you please check if this error is coming to you?
And what is the code of the flow? Where to see it?
var Arr1 = Buffer.from([0xaa,0x3f,0x00,0x00,0xf0,0x11]); msg.payload = Arr1; return msg;
If this is what you have in function 4 you must have changed it because I can say 100% certainty you would not get [ 170, 63, 0, 17 ]
You WOULD get [170,63,0,0,240,17]
- Please confirm the payload going → to → Serial Node (what do you see in debug)
- Did you change the Serial Port setting to "deliver" binary / buffer?
Using buffer-parser / buffer-maker...
Here is a demo of making a buffer, calculating a CRC then appending it to the data, to generate a final buffer for transmission to a serial or network device...
Demo Flow (use CTRL-I to import)
[{"id":"1b1e6cd3345cb250","type":"inject","z":"f888b812e6b0fc73","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"aa2b0000","payloadType":"str","x":880,"y":740,"wires":[["c3e3c4e9c75f1ebb"]]},{"id":"e0d2df440975a5ea","type":"debug","z":"f888b812e6b0fc73","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"crc","targetType":"msg","statusVal":"","statusType":"auto","x":1320,"y":800,"wires":[]},{"id":"9f66087a29681310","type":"function","z":"f888b812e6b0fc73","name":"Calculate CRC16","func":"function crc16(data) {\n const buf = Buffer.isBuffer(data) ? data : Buffer.from(data, 'hex')\n let crc = 0xFFFF;\n for (let i = 0; i < buf.length; i++) {\n crc = crc ^ buf[i];\n for (let j = 0; j < 8; j++) {\n const temp = crc & 0x01;\n crc >>= 0x01;\n if (temp == 0x01) {\n crc ^= 0xA001;\n }\n }\n }\n return crc;\n}\n\nmsg.crc = crc16(msg.data)\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":740,"wires":[["e0d2df440975a5ea","742cb4936f6b8153"]]},{"id":"c3e3c4e9c75f1ebb","type":"buffer-maker","z":"f888b812e6b0fc73","name":"","specification":"spec","specificationType":"ui","items":[{"name":"data","type":"hex","length":-1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"data","msgPropertyType":"str","x":1090,"y":740,"wires":[["8c51ca3a6bfaf4f5","9f66087a29681310"]]},{"id":"8c51ca3a6bfaf4f5","type":"debug","z":"f888b812e6b0fc73","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"data","targetType":"msg","statusVal":"","statusType":"auto","x":1100,"y":800,"wires":[]},{"id":"742cb4936f6b8153","type":"buffer-maker","z":"f888b812e6b0fc73","name":"join data + crc","specification":"spec","specificationType":"ui","items":[{"name":"data","type":"buffer","length":-1,"dataType":"msg","data":"data"},{"name":"crc","type":"uint16be","length":1,"dataType":"msg","data":"crc"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":1520,"y":740,"wires":[["ed4b127af8f41b76"]]},{"id":"ed4b127af8f41b76","type":"debug","z":"f888b812e6b0fc73","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1550,"y":800,"wires":[]},{"id":"a1e71dedcb1e9749","type":"inject","z":"f888b812e6b0fc73","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"aa3f0000","payloadType":"str","x":880,"y":700,"wires":[["c3e3c4e9c75f1ebb"]]},{"id":"93d14ab247ad849f","type":"inject","z":"f888b812e6b0fc73","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"aa1a0002ffff","payloadType":"str","x":890,"y":780,"wires":[["c3e3c4e9c75f1ebb"]]}]
Thanks for replying, yes the content of the function and the reply before was for this:
var buf = Buffer.from([0xaa,0x3f,0x00,0xf011]); /* 170, 63, 0, 17 */ msg.payload = buf; return msg;
Then I rewrote it in this form:
var buf = Buffer.from([0xaa, 0x3f, 0x00, 0x00, 0xf0, 0x11]); msg.payload = buf; return msg;
- I have changed the Serial Port Setting to delivering binary buffer.
- The error:
is coming from the Serial Node and not from the debugger attached to it. The serial node will stay waiting until I redeploy something and then also no response from the debugger attached to the serial node.
there is more going on that you have shown
is there more than one node named "keyto"?
when you hover over that error which node is highlighted?
your "deploy" button is lit-up - is what I am seeing actually deployed?
PS, why are you sending photographs? Can you not connect to the node-red server/device using its IP? e.g. http://IP-OF-NODE-RED:1880. Then you can use the "Copy Value" button on the debug nodes & take screenshots on your PC/Laptop instead of taking photos of a monitor?!?
can you export this flow (CTRL-E) and paste it into a reply
paste copied flow between three backticks like this
The flow is:
"id": "e7e0acf8ed94f75e",
"type": "tab",
"label": "Keyto",
"disabled": false,
"info": "",
"env": []
"id": "067e0acd2d271669",
"type": "inject",
"z": "e7e0acf8ed94f75e",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "aa3f0000f011",
"payloadType": "str",
"x": 190,
"y": 1000,
"0e3b76dd644213b3"
"id": "0e3b76dd644213b3",
"type": "buffer-maker",
"specification": "spec",
"specificationType": "ui",
"items": [
"name": "item1",
"type": "hex",
"length": 12,
"dataType": "msg",
"data": "payload"
"swap1": "",
"swap2": "swap16",
"swap3": "",
"swap1Type": "swap",
"swap2Type": "swap",
"swap3Type": "swap",
"msgProperty": "payload",
"msgPropertyType": "str",
"x": 410,
"y": 1000,
"1defe32f1f4fd013",
"197bffe1203be388"
"id": "1defe32f1f4fd013",
"type": "debug",
"name": "debug 13",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 400,
"y": 1120,
"id": "197bffe1203be388",
"type": "serial request",
"name": "keyto",
"serial": "22f712114a9952dd",
"x": 670,
"y": 1000,
"b30f1f7458ccaa75"
"id": "b30f1f7458ccaa75",
"type": "debug",
"name": "debug 14",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"x": 690,
"y": 1120,
"id": "22f712114a9952dd",
"serialport": "COM1",
"serialbaud": "38400",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"dtr": "none",
"rts": "none",
"cts": "none",
"dsr": "none",
"newline": "50",
"bin": "bin",
"out": "interbyte",
"addchar": " ",
Ok - there is a small bug in serial port in that it isn't quite doing what it is supposed to... - but you have somehow managed to add two spaces in the "add to output" field
- the node is failing to append these two spaces (which is the bug causing the error) - but you need to remove those spaces... and then it will work...
v1.0.2 now on flows (but the fix will mean the buffer would then contain 20 20 at the end ![]()
